New sparkplugs/air filter = bad mileage
My wife daily drives a 99 4Runner. I replaced the spark plugs with the correct Toyota dual electrode plugs. I also replaced the air-filter with a new Toyota filter. Now her gas mileage seems bad. I have an OBDII scanner so I connected it, and it shows no codes. I thought a plug may not be firing. If the truck was misfiring, wouldn't the OBDII tell me?
The truck drives as I would expect, with no power loss.
BTW this is a crosspost from the 4runner.org forums.
pull all the plugs one by one and check them...look for fouled plugs or plugs covered in fuel...and check to make sure everything is gapped correctly. also, check your spark plug wires, if they are old, maybe your gettin a bit of arcing, or they are absorbing moisture
I don't think you can gap the dual electrode plugs? Either way, I do need to read the plugs and see if anything is obvious. It seems like if there were a misfire, the OBDII would catch it.
I didn't reset the ECU, didn't even think about it. I'll try that tonight. That would make sense. The truck runs fine, no misses, scanner shows no codes so I think thats a really good tip.
So it sounds like you had bad mileage BERFORE the tune up ...right??
Sounds like a classic O2 sensor needs replacing if your near 75,000
My mileage went south at 75,000 for no reason with no codes or bad running.
I could watch the guafe drop! Literally.
I just installed the #1 sensor to the front of the cat. 139.00!!!
There is a tech article out there on 4X4wire.com that explains this.
could be your deal...........Kenny S.
99 4runner 3.4 V6
99 4runner 3.4 V6
99 4runner 3.4 V6
99 4runner 3.4 V6
There are two 02 sensors, one in the front and one in the rear.
You should reset the ECU first, though...and worry about the 02 sensors a little after, should everything more or less return the way it was. They do tend to go bad after 75k and they do affect mileage, so it might not be a bad idea to replace them.
My mileage was looking REALLY awful 'till I replaced both 02 sensors. Now it's more or less OK.
Ditto on the above.....pull the neg batt cable, reset the ECU and drive to check mileage. If your mileage is still bad you can start looking at the MAF and front O2 sensor as possible culprits. Often the ECU just needs time to adjust and may run poorly until new fuel trims have been established (the ECU reset just accelerates this process).
How did the plugs look by the way? All same color?
Yeah, they were all the same color. I don't think she has ever changed them either. They were pretty used up though. The center electrode had nice divots where the 2 outside electrodes are. Something that surprised me... One side of the engine had factory plugs, the other side had NGK's. All dual electrode, just different mfr. Like I said, I don't think she has ever changed the plugs and she is the original owner of the truck. Thats one of the reasons I was surprised at her fuel consumption. The old plugs were so tired, I thought for sure she would see better mileage. I'm unplugging the battery tonight. For what 5 or 10 minutes? Will she lose her radio stations?
Yes, you'll need to redo the stations. You can try pluuing the ECU fuse, but I prefer the batt cable since I have seen cases where the fuse didn't reset everything properly. Your call on that though.....about 5-10 min is more than enough.
Yep, those were definately the original plugs because the vehicles came from the factory with Denso pulgs in one cylinder bank and NGK in the other. Usually you can tell the plugs have been changed at least once when they are all the same brand (all Denso or all NGK).
Well, obviously there may be an anomaly here and there (pehaps in manufacturing supply, perhaps they had been changed at the dealer prior to delivery, etc). I would still maintain that if you have Densos on one bank and NGKs on the other, you're probably dealing with the original plugs on the vehicle.
I wonder if Toyota stocks the heads at the factory with the plugs pre-loaded? When they pick the parts for assembly, you get whatever plugs were pre-loaded in the heads. Thats the only explanation I can come up with.
BTW I reset the ECU last night, so hopefully that cures the MPG problem, Thanks for the tips.
Well, I wouldn't go as far as saying that isn't true; I had the same exact thing and I've heard of others having a 50/50 of Denso/NGK plugs from the factory...for instance, my '96 had Denso plugs on one side and NGK on the other. They were original...pretty much everything was original, actually, when I bought it....10 years after it was made
Let's not hijack AZjason's thread too badly here though.
