New Shocks for 4Runner --- which ones?
1 Post
It has been a while since I have posted. I have already read through the numerous threads on this subject and there are many options and even more opinions. I want to check the latest pulse on this subject and would like to only hear from Gen3 (96 - 02) 4Runner owners, not Tacoma or other PU truck owners --- please.
I have narrowed my options down to three possible choices:
1) Monroe Sensa-Trac?
2) Tokico Trek Master?
3) Bilstein?
I have Addco front and rear bars as well as HR progressive rate springs front and rear. The vehicle has 40K miles now.
I realize that I am trying to tame a top heavy brick but I want a relatively smooth ride that doesn't telegraph every pebble on the road to my butt. If I can avoid a rock hard ride, the most important thing to me is improving the cornering characteristics. My application is 90% paved and graded dirt road usage.
TIA for the feedback.
3) Bilstein?
are the HR springs u have the same ones as the PP springs? if so, go with bilsteins.
www.cabeperformance.com had them for cheap when i bought them
1 Post
[QUOTE=Localmotion]are the HR springs u have the same ones as the PP springs? if so, go with bilsteins.
Yes, they are the springs sold by PP. It really pissed me off when I bought them because I wanted the "red" ones that were suppose to lower the vehicle by 1" all around. PP insisted that I had the correct PN and the color did not matter. However, the vehicle height remained at its OEM level and actually the rear was raised up slightly. Anyway, I like the springs but find that the transition during cornering is not smooth or gradual. In other words, it leans slightly then all of a sudden hunkers down and remains stable. I have Eibach progressive rate springs on another vehicle and they do not perform that way. That is why I want a shock that will enhance the cornering characteristics --- the way Koni's do, BUT does not give a rock hard ride.
Although I have Bilsteins on another vehicle and was relatively happy with them, I am told they do not last and one 4R owner told me they were too stiff on his 4R. I cannot imagine Bilsteins being too stiff but I believe this man.
1 Post
Originally Posted by Boaz
have you considered Pro Comp Shocks?
I bought bils and shortly sold them for OMEs. It wasnt that i was disappointed with them, I just wanted to lift my junk.
I gave my cousion my bils (hes got a 98 ltd) and he loves them. Id say the overall handling improved. I think the HR springs were made to be used in conjunction with the BILS. FilthyRich has them on his wifes 4runner. Ask him for more details.
Matt
Matt
Originally Posted by 4RocRunner92
its junk all right localmotion.
I run bilsteins.
I run bilsteins.
LOL
I have a 3rd gen w/ stock springs (w/ spacers) and Bilsteins. At first, there was a ton of "float" when hitting windy roads at higher speeds (mostly freeways). After installing Addco's, the handling improved dramatically.
What I like about the Bils is the instant compression when you hit a bump. The thing that others don't like about this is it makes the suspension feel stiffer. When I'm driving through rough patches, the Bils are definitely stiff but I don't experience this (type of road) all the time.
When I did my research, Tokiko's were highly recommended as a slight improvement over stock but with better handling. If this is what you're looking for, you should probably go Tokiko. From my prior experiences w/ suspensions on cars, Bils were always the bette way to go on heavier vehicles. Good luck.
1 Post
Can you compare the 3?
Okay, so is it possible that someone has gone deep enough into this subject that they can compare the three shocks in terms of ride and handling?
3) Bilstein?
3) Bilstein?
1 Post
Originally Posted by ebelen1
...After installing Addco's, the handling improved dramatically.
1 Post
For what is worth, I installed Tokico shocks on my wife's Avalon XLS and it made a significant difference in the ride and definitely in the handling. That is not saying it will do the same on my 4R but I thought I would offer that up for anyone of us Yota lovers who has an Ava or other such sedan in their family.
We had a discussion about suspensions here a long time ago and I said then that according to a very well respected and nationally known race car builder (now retired), the way he wanted NASCAR vehicles to perform was for them to "float" over bumps and squat down in turns. What this meant to me was that I should not be opposed to a slight amount of rebound from shocks, the kind of rebound that could be interpreted as a soft ride. What I wanted was for them to be stiff during cornering. That is why I think Koni shocks are so good; as I recall they have unique valve engineering that compensates for leaning. Too bad they do not make them for 4R's.
I had the pp springs and the bilsteins but felt it was too stiff, so I swapped the bilsteins with tokiko trekmasters. Still a little stiff but not as much as earlier.
Anyone know which is stiffer, the pp or ome (soft)?
1 Post
Question RE rear spring BUMPSTOPS
I have another questionr relating to the HR springs. There has been talk about cutting the bump stops in the rear. Is there a writeup on the procedure and how much to cut the bumpstops?
http://cgi.ebay.com/ebaymotors/TOKIC...spagenameZWDVW
Please post back and let us know how they feel. I'm in the same boat as you, I just didn't want to be the guinnea pig.
thanks
thanks
Well I dont think either of you will be dissapointed at all. I have went through stocks, Bils and now I have the trek masters and I like them the best.
They have great street characteristics and are about as stiff as I would like on the street; but still do quite well in cornering and slight offroading. I drive 90% street and got the tokico's because of the charecteristics and the $200 shipped price off ebay.
I have driven them in ALL conditions now, for about 8k miles and I cannot imagine gettign anything else for a daily Runner that doesn't see much offroad. They feel MUCH better in corners than stock and are noticeable stiffer as well (not as bad as Bils though).
There are other springs out there besides PP and OME. Downey also has springs for 3rd gens and comparably priced to PP. I don't know about stiffness on them though. Good luck.
