YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-18-2004, 06:33 PM   #1 (permalink)
colsoncj's Avatar
Send a message via AIM to colsoncj
Question New problem: No rear brakes...
So I went to bleed the rear brakes today and I got nothing. When I undid the wheel cylinder, no fluid came out of the line. When I went to bleed the new cylinder, nothing again. My guess is the rear proportioning valve is blocked. Anyone ever had problems like this, or any suggestions?
__________________
Cory
Eastern OK, Western/Northern AR, Southeastern KS, or Southern MO area: OZARKS 4ROC Click Here
04 Dodge 2500 Cummins - DD/Tow Rig
02 Z06 Corvette - Weekender
94 FZJ80 - Wheelin Rig. Currently on 33"s, plan to go 35"s.
72 Buick GS - i.e. the project that will never get done.
colsoncj is offline
Sponsored Links
To remove this ad, register today!
Old 09-20-2004, 02:08 PM   #2 (permalink)
colsoncj's Avatar
I looked under there again and noticed my bar for the rear load valve was bent, is that normal? I haven't had a chance to figure out what the problem is, I don't have a place to work on it at the moment, but any help on diagnosing the problem as to why i don't have fluid coming out of the rear would be great!
__________________
Cory
colsoncj is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
NO BRAKES!!!!! Brake problem Adawg_08 86-95 Trucks & 4Runners 6 03-17-2007 08:16 AM
Rear Brakes turns into rear axle replacement? AirWolfe1 95.5-2004 Tacomas & 96-2002 4Runners 2 07-17-2006 09:45 AM
Brakes Problem: Pads or Rotor? Super Doody Maintenance & Repair Archives 3 08-29-2005 10:03 PM
problem with rear drum brakes Localmotion Maintenance & Repair Archives 10 05-04-2005 10:34 AM
Rear brakes R&R how to needed. frnt brakes replaced 2X. arielb1 95.5-2004 Tacomas & 96-2002 4Runners 12 12-18-2004 05:10 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
