New Plugs
Old 05-19-2003, 06:35 PM
XtremeOff-Road's Avatar
New Plugs
Alright everyone, I received the new plugs tonight...I will throw them on in the next day or two and report back on their performance. Here are two pics for you
Old 05-19-2003, 07:21 PM
thowho1985's Avatar
sorry if this sounds like a dumb question, but would you have to gap something like that? Are the prongs just like 3 prongs of a normal plug?
Old 05-20-2003, 08:45 AM
Mikey's Avatar
On a lot of them like this plug you can't gap them. There preset at the factory and are ship with a plastic guarding around the electrode so that if they are dropped in shipment they won't affect the gap.
Old 05-20-2003, 08:48 AM
SLC Punk's Avatar
Are those the bcpr7et (Gadget recommend plug)? I installed a set of those in Feb. Now I only ping on rare occasions.
Old 05-20-2003, 09:47 AM
Actually no they are Zex plugs....82003
They are designed for vehicles equipped with S/C's, Turbos, or Nitrous
Mike
Old 05-20-2003, 09:49 AM
Away
Dr. Zhivago's Avatar
So, is the TRD Thermo finally installed?
Waiting with baited breath...
Dr. Z
Old 05-20-2003, 10:05 AM
pfdaxe's Avatar
I installed the Denso 1 step cooler Irridium plugs and the TRD stat and to be honest......I didn't notice any difference.
Old 05-20-2003, 06:23 PM
Ok here is my initial results on these plugs...Ping is gone...we will see what the future brings, however, at this time it is gone. Bottom end seems a tad stronger, could have to do with just having new plugs though.
As some of you know, I have only been getting about 160 miles to a tank of gas, we will see now if this improves...Also, something a little strange...when removing the factory plugs guess what I noticed...Drivers side and passenger side plugs were different...two different heat ranges, hmmmm :confused:
Mike
Old 05-20-2003, 06:30 PM
Vato Loco's Avatar
So Im guessing the plugs aren't any good for the N/A 4Runners
Old 05-21-2003, 05:34 AM
donc's Avatar
Plugs
My 95 3.0 had the same thing - different plugs on each side of the engine - I even went back and was told that I did a bad thing by not installing teh same type of plugs when I changed them. This was from a "factory trained" Toyota mechanic. I told him that this was the first time the plugs had been changed (22K miles). I never got a "good" answer from anyone on why the plugs were different.
Old 05-21-2003, 06:10 AM
Senior Member
data's Avatar
160 Miles on a full tank I hope you don't commute far to work...
Old 05-21-2003, 06:19 AM
pfdaxe's Avatar
Mike:
I take it you haven't done the TSB for the fuel gauge??
I use to get around 200 miles before having to fill-up before and now goes about 280. Even thought the tank obviously doesn't hold anymore, it sure fells nice not having to add fuel every couple days.
Paul
Old 05-21-2003, 07:08 AM
What is wrong with the fuel gauge??
Mike
Old 05-21-2003, 07:21 AM
pfdaxe's Avatar
Mike:
It's actually the fuel sending unit that is bad on the 3rd gens. The fuel gauge doesn't read the correct fuel level in the tank therefore when your fuel light comes on, you actually have 4-5 gallons still in the tank. Plus, once the sending unit is replaced the gauge stays on FULL alot longer.
Check these threads:
https://www.yotatech.com/forums/show...&highlight=tsb
Paul
ps...ya gonna make it to Pavillions on the 31st??
Blamalam
03-12-2022 07:34 AM
old87yota
10-25-2015 02:15 PM
80Truck
07-24-2015 03:12 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
msane99
07-17-2015 10:13 AM
Quick Reply: New Plugs
