NEW MOD - 12V Power outlet in console - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-14-2003, 04:13 AM   #1 (permalink)
ManyMods's Avatar
I just thought I would share my latest silly little mod ... it may have been done before.
I don't like seeing wires strewn across my forward (shifter) console where the two 12V outlets are so I thought it would be nice to have an outlet at the rear of the center console. (I use a Motorola portable hands-free phone kit that needs a 12V source.)
In deciding how to do the mod the one requirement I had was that I would not drill any holes or do anything that could not be easily reversed.
I ordered one black 12V outlet housing and cover from Toyota:
85530-06010 housing $12.86
85535-35050 cover $6.77
I disassembled the console and dash area and removed the console box from the vehicle. On the bench I removed the ashtray and then carefully pried up the three little tabs at the rear of the ashtray compartment. This allowed the trim ring on the face of the console box to separate from the rest of the compartment. I then removed it from the console.
I used 1/8” thick pebble grain black vinyl sheet stock that I got for making backing plates for stereo installs (I think I got it from PartsExpress) and cut out a plate the size of the recessed area of the ashtray opening. I used the ashtray trim ring to make a template. The next question was how to attach the plate to the console box. I used clear plastic tabs, the kind that are used to attach mirrors to walls and doors in your home. The tabs I had were for ¼” plate glass so I planed them down to have the necessary depth… 1/8”. Then I beveled them slightly on the inner face of the tab so that they would have better purchase on the inner edges of the console box. I know this is hard to visualize but once you are into the project it should become clear by simple reasoning. I drilled two holes in the plate I made on the left and right sides, in about ¼” from the edges and used two black #8 x 5/8"sheet metal screws with washers. The black screws/washers are sold at places like Pep Boys and are used for securing door panels, dash boards and other integral parts. The screws cut into the screw holes in the clear tabs allowing me to tighten them down and secure the plate to the console. Before I did that I drilled a 1” hole with a Unibit into the plate I made and then enlarged it with a Dremel and notched it in the appropriate place so that the new 12V housing would slide in and lock in place. In order to provide the proper clearance for the cup holder I had to bend the +/- tabs perpendicular to the housing.
The wiring harness was made to run forward and lineman splices were made into the leads of one of the two 12V outlets at the dash. The OE wires are B/R (+) and W/B(-). I used 16 awg hookup wire, put a Molex 2-wire connector in line just behind the shifters so that if I need to remove the console box I can simply disconnect the harness at that point and pull the box. The rest of the harness was permanently attached to the box so that it would not interfere with anything and push-on female crimp connectors were used for the connection to the blade tabs on the 12V outlet housing.
Make sure that your connections are sleeved and taped so that there is no chance of a short at any time and solder as many of the connections as you can if you want to do it right.
I chose to use the black vinyl material and black 12V plug/cover instead of painting it to match the console box. I also used the 1/8” material because I wanted the rigidity it provided. I tried a thinner material but it flexed too much when pushing or pulling a plug at the socket and I didn’t like that.
That is it. It was a fun little project and took care of my mental health needs for a day or two.
:pat:
__________________
- Peter
2002 4Runner 4wd Limited - Millennium Silver
TRD Gen2 Supercharger w/ 7th Injector, TRD boost gauge
TRD catback exhaust, TRD transmission cooler
IPT valve body recalibration, Transmission temp gauge
Walbro 190 ltr/hr fuel pump
Beckson deckplate mod, Amsoil air filter, Dr. Z. ISR Mod
Addco "RED" F&R anti-sway bars
H&R progressive springs
Alpine CDA-9835, Infinity RS speakers & 2 BassLink SUBS
XM Radio
and Many Mods
ManyMods is offline
Old 08-14-2003, 05:35 AM   #2 (permalink)
broknlgs24's Avatar
Send a message via AIM to broknlgs24 Send a message via Yahoo to broknlgs24
pics?
i noticed that u are S/C'd and also have the ISR Mod. Was this Mod beneficial w/ the S/C? i also notice that u have the TRD Exhaust w/ Addco Swaybars. did/do u have any issues w/ them rubbing?
broknlgs24 is offline
Old 08-14-2003, 05:44 AM   #3 (permalink)
ManyMods's Avatar
That is always a problem for me and the easiest way is for me to send them to you at your private email. Send me a PM if you want me to do it that way or when I have time I will refresh my memory on how to get them attached on the board.
__________________
- Peter
XM Radio
and Many Mods
ManyMods is offline
Old 08-14-2003, 06:00 AM   #4 (permalink)
ManyMods's Avatar
broknlgs24 -
You have a PM
__________________
- Peter
XM Radio
and Many Mods
ManyMods is offline
Old 08-15-2003, 07:32 PM   #5 (permalink)
ManyMods's Avatar
Picture of 12V outlet
Here is a picture of the completed installation if anyone is interested.
__________________
- Peter
XM Radio
and Many Mods
ManyMods is offline
Tags
0utlet, 12v, 4runner, black, caps, connection, console, install, laptop, make, mod, outlet, outlets, power, vehicle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
99 4runner constant 12v outlet mod oxfordethan Newbie Tech Section 5 03-23-2007 07:04 PM
12v power outlet question sdstud212001 95.5-2004 Tacomas & 96-2002 4Runners 20 08-12-2006 11:11 PM
Full Time Power Outlet Mod - 99 4Runner Bob_98SR5 Electrical 0 12-31-2005 08:12 PM
12V outlet caps garrett1478 95.5-2004 Tacomas & 96-2002 4Runners 4 08-09-2005 01:19 PM
Full time power outlet MOD fooddude 95.5-2004 Tacomas & 96-2002 4Runners 14 02-23-2004 01:01 PM
2009 InternetBrands, Inc.
