New to me 91 4Runner questions
Old 10-12-2005, 11:54 AM
Tigerstripe40's Avatar
I've been in land Cruiser FJ40 world for quite some time.
I just picked up a 1991 4Runner SR50 V6 with 218,000 miles on the clock. And I feel I got a KILLER deal on the truck.
The body and interior is pretty nice, but the trucks drivetrain needs a little work.
This rig isn't going to be used for extreme offroading, I have the fj40 for that. Mostly long range trips out to the desert camping, and the like.
First thing is, the truck runs, but it's running pretty rough. The truck has an intermittant rod knock. SOmetimes it's there, sometimes it's not. FWIW, I am planning on replacing or rebuilding the motor at some time. But when I rev the truck over 3500 rpm it gets VERY rough.
The head gasket recall was done, and it looks like NEW heads were put onto the truck at about 119k miles.
I found a rebuilt shortblock locally for $1000. I am leaning towards this route, as well as new OEM head gaskets, and the ARP head stud kit from DOA Racing .
However, I have found a motor with 60k miles for $1750 locally.
I did find a motor with 40k miles for $950, but it's teh 3VZ out of a Camry, which I am informed won't work. Is this true?
Next, the fan clutch idler bracket is broken. I have a new one on the way. But in the mean time the alternator is not hooked up. I tried to turn on the A/C but the light on the switch didn't come on, and the compressor didn't spin up. I can't find the fuse or the relays for the AC system. CAn anybody point me in the right direction?
Lastly, the Cruise Control doesn't seem to be working properly. I hit the button, and the 'Cruise' light comes on solid, but when I hit the set button it doesn't set the speed. I know that if there is a problem with one of the components, the 'Cruise' light will blink. THis isn't happening. I think it might also be a fuse, but I Can't find it on the drives kick panel nor under the hood.
Anyhow, nice forum you've got here, and thanks for any input!!!
Old 10-12-2005, 10:29 PM
Elton's Avatar
sorry i cant help u hear's a bump
Old 10-13-2005, 02:08 AM
rocket's Avatar
So many questions in one thread is a little too much...hence the zero replies.
Use the Search option for your problems first and then figure out what you need help with most. Starting a new thread with one or two questions will get you replies.
Old 10-13-2005, 06:39 AM
celica's Avatar
For the A/C see if the light on the switch is burnt out. The compressor will not spin up if the pressure in the system is too low.
Old 10-13-2005, 07:26 AM
I found the FSM for a 1993 4Runner on the net in .pdf format.
THe A/C is simply a burnt fuse. Located behind the glove box, so it's a bit of a PITA, but I replaced that and the AC blows nice and cold (not that I will need that for much longer...)
mdev126
10-04-2015 04:48 AM
TURBOrunnerNM
07-22-2015 11:01 AM
87turboPA
07-12-2015 07:49 AM
Cplmike
07-08-2015 08:47 PM
Quick Reply: New to me 91 4Runner questions
