New (to me) 2000 4Runner, what maintenance would you recommend
Greetings all!
I am proud to share that my wife and I have purchased a 2000 Limited 4Runner. Got it for $8,000 with 136K. Seems to be be good shape. I'll post some pics later in the intro section. However, considering it has 136K and the only routine maintenance I know about it is that the timing belt was changed at 90K, I did what I thought needed to be done on most vehicles that age.
The things I have done:
spark plugs and wires (OEM)
Fuel Filter (OEM)
Oil and filer (AMSOIL)
AT flush (AMSOIL)
Tundra brake, caliper and rotor upgrade (Advanced Auto for reman OEM calipers, OEM brake pads and OEM rotors from carpartsdiscount.com)
MAF sensor cleaning (Autozone)
New brake fluid (AMSOIL)
* OEM parts ordered from toyotapartszone.com unless otherwise stated.
To do list:
Coolant flush
Repack bearings
Differential lube change
Air filter (actually considering performance air intake systems, advice is welcomed )
Grease drive train
Now, I request the wisdom of the Yotatech forum for what other maintenance I should perform on the 4Runner. Surely there elements that I have missed and some 3rd Gen specific things. Please offer any and all suggestions. Thanks in advance!
Fuel Filter (OEM)
AT flush (AMSOIL)
To do list:
Coolant flush
Repack bearings
Grease drive train
I see you're going to do a coolant flush soon, but also keep an eye on your radiator, or look into getting a external tranny cooler sometime in the future. Not sure if you've heard of the 'Strawberry Milkshake', but it's a pretty bad mess if you get it. I changed my radiator maybe 8 months ago and started to notice it might have been happening to be, and I was at about 130k. Also have the 3.4 Auto, not sure about you. Besides that it looks like you're pretty up to date on your stuff, good choice with the Tundra brake swap by the way!
+1 on looking at replacing the radiator, or at least looking at adding an external transmission cooler to prevent the pink milkshake. If you replace the radiator, get a new cap and hoses (OEM) at the same time. Toyota red is the way to go or the Zerex equivalent.
Check to see if the PCV rattles. Clean the throttle body. Tighten slack in control cables to TB.
4WD? Look at the lower ball joints for cracks in the boots.
Bearings are sealed, so if they go, have a press at your disposal. The rubber sway bar bushings may need replacing by this time. Since you seem to be rather fastidious with maintenance, I'd flush the power steering system and use some of the Amsoil ATF as new fluid.
Use the search engine here for other topics.
Thanks for the info guys. Appreciate your input. With good care and maintenance I am hoping for 300K :wink:
That is a good call on the radiator. I ordered a B&M 70264 and remote filter that should be in today. Don't plan on doing that much towing but $100 for both is cheap insurance for the Tranny. It will be interesting to see if I already have sign of the dreaded "Pink Milkshake" when I still it. I will let ya know!
Not sure if I am going to replace the radiator. I'll have a good look at it when I flush it with the rest of the coolant and install the tranny cooler. If indeed it does need to be replaced, I will certainly take your advice and do the hoses as well. Definitely adding the PCV and throttle body to the to do list. Moving this weekend but hope to get around to that after.Took a look at all boots and I dont see and cracks yet. I'll make sure to keep an eye on em. I will likely get around to the power sterring fluid flush, however, it is working well and I think the others items on the to do list are more urgent.
flush all diffs, not just the rear-consider going synthetic.
Opinions vary on this of course so get several opinions/read up a lot on here and T4R.org
Clean and treat the leather seats.
Enjoy the new to you ride.
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
Jnkml
07-06-2015 01:20 PM
