New Lights
New Lights
I'm putting 4 100-watt lights on my roof rack this weekend. I have the brackets from Surco, 2 30-amp switches and 100 feet of 10ga. wire. Anybody see any probs with this?
I plan to run the wires behind the rainseal behind the doors then into the engine compartment. Switches will go on center console.
Any Tips?
Lamm
Any Tips?
Lamm
I think relays would be a wise decision. W/o relays, the power runs into the switches and can run into problems... Relays are always safer but then again if ya got some big 'ol switches that handle the load, I suppose it's all good!
Yep, I see problems.
As stated, you should always use relays.
There is an old post here by me and a newer one by someone else on how to figure out the size of the relay you need for the wattage of your lamps.
Also please see the Tech section, as I have a write-up in there on how to wire up off road lights.
Here it is.
Here it is.
ashersullivan88yota
01-18-2022 05:37 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
09-01-2015 08:05 AM
PopsDad1
07-30-2015 02:21 PM
Odin
07-15-2015 09:28 PM
