New Idea on How to Run 2 Topouts...
Old 11-01-2007, 08:07 AM
Nate08's Avatar
Instead of limiting straps...how about stacking washers and bringing up the bumpstomps of the lower control arm? Seems like it would serve the same purpose?
Old 11-01-2007, 04:24 PM
rocktown's Avatar
Two top out spacers are bad because of excessive droop, which creates extreme cv angles and thus breakage. Using limiting straps lets you control how much the suspension droops. Raising the bumpstops on the lower arms would just reduce suspension travel, that wouldnt do anything to prevent excessive droop.
Old 11-01-2007, 04:37 PM
Nate08's Avatar
Define your term of "droop".
Old 11-01-2007, 04:50 PM
KZN185W's Avatar
Droop is the downward travel of the suspension.
The stacked washers that you mentioned doesn't limit the downward travel. It can only limit the upward travel. A limiting strap is needed to limit the downward travel.
hth
Old 11-01-2007, 06:09 PM
waskillywabbit's Avatar
This has been discussed several times before on this forum and it is a BAD idea.
Old 11-02-2007, 03:30 AM
Nate08's Avatar
There just seems to be alot of people running 2.5" or 3" spacers. I don't see how 2 topouts could be worse.
Old 11-02-2007, 06:12 AM
Bighead's Avatar
I assume you are talking about the Daystar-style lift spacers. Those spacers are providing the lift and are not being used in conjunction with a lift spring. They are on top of a stock spring.
Old 11-02-2007, 07:25 AM
SLC97SR5's Avatar
You should try wheeling it hard at full lock with 2 Top-outs and lots of traction. Make sure to bring you hubn socket and a new CV.
Old 11-02-2007, 08:03 AM
Nate08's Avatar
[QUOTE=Bighead;50657666]I assume you are talking about the Daystar-style lift spacers. Those spacers are providing the lift and are not being used in conjunction with a lift spring. They are on top of a stock spring.[/QUOTE
Gotcha, thanks for clearing it up.
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
Colington
03-08-2020 09:51 AM
09-04-2015 09:27 AM
88runnergomas
07-09-2015 01:12 PM
Quick Reply: New Idea on How to Run 2 Topouts...
