New here and need help with upper ball joint - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 07-14-2006, 07:34 AM   #1 (permalink)
I have read through many threads about this. Does an auto parts store carry a ball joint press that is strong enough to press that ball joint into the spindle?
How hard is it to get the spindle off and just bring it into Meineke and have them press it in there for me. Whats the easiest option? Please help asap as I without a truck right now.
Thanks guys!!!!
Stal is offline
Old 07-14-2006, 10:40 AM   #2 (permalink)
hamstrungtaco's Avatar
i pressed mine in with a piece of pipe in a vise, kinda tricky but it worked
__________________
99 xcb 2.7, enough said
02 trans am ws6
hamstrungtaco is offline
Old 07-14-2006, 10:48 AM   #3 (permalink)
So you had to pull the spindle out of the truck?
Stal is offline
Old 07-14-2006, 01:41 PM   #4 (permalink)
Tanto's Avatar
The factory Upper ball joint is attached to the spindle, so yes, you will have to at least disconnect your upper control arm to work with it. Taking the spindle off the truck makes it MUCH easier to do. To take out the old ball joint, just find a socket that is just a tad smaller than the ball joint and use a hammer to knock it out. Autozone will loan you a ball joint press, but I believe the deposit (that you get back if you return it) is around $140. The Autozone one is kinda crappy but you can make it work pressing your new balljoint in.
__________________
"Prepare for the worst, hope for the best"
2002 Tacoma Doublecab - "TURTLE TACO" Just a bunch of bling on a truck...
Quote:
Originally Posted by deathrunner
Yeah, and my mom's still mad at you.
Tanto is offline
Old 07-14-2006, 02:08 PM   #5 (permalink)
Crux's Avatar
I could never get the ball joint press to work because the spindle top section curves and won't allow the press to seat correctly.
I just ended up taking both spindles into Midas and having them use a shop press to get the new upper ball joints in.
__________________
97 4Runner SR5 Blue - 135k miles, E-Locker, Armorology front/rear bumpers & sliders, BudBuilt skidplate+belly, MTR 285/75/16s, 2" Tundra/OME Lift, 1" 4Crawler Bodylift, 1" diff drop, Black Aluminum Wheels, Cobra CB
04 Land Cruiser Grey - 90k miles, OME Lift, Slee Sliders, 35" Toyo Muds
Crux is offline
Old 07-14-2006, 08:14 PM   #6 (permalink)
KyleT's Avatar
i used a kit from a local auto supply and an assortment of very large sockets (1" drive) and jimmy rigged it untill it popped free. i let it soak good with PB blaster overnight before hand as well.
__________________
- Kyle
Former Owner of -
1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06
OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2
KyleT is offline
Old 07-15-2006, 07:19 AM   #7 (permalink)
Ok I got it. I went to Advance Auto Parts and rented a ball joint press. It was an impressive kit. I had no problems at all. I would recommend this to others who have to try this.
Thank you all for the imput!!!!!!!!!!!!!!!!!
Stal is offline
Old 07-15-2006, 08:12 AM   #8 (permalink)
Tanto's Avatar
No problem. Glad to hear that everything worked out for you!
__________________
Tanto is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Upper Ball Joint TRDatVT 95.5-2004 Tacomas & 96-2002 4Runners 7 04-04-2007 05:35 AM
How to replace upper ball joint Localmotion 95.5-2004 Tacomas & 96-2002 4Runners 5 02-04-2007 06:46 PM
replacing upper ball joint jeepboyny 86-95 Trucks & 4Runners 14 10-06-2006 07:18 AM
Upper Ball joint mystery? PLEASE HELP! SuaveGato 95.5-2004 Tacomas & 96-2002 4Runners 10 06-16-2006 10:55 AM
upper ball joint Godzilla 95.5-2004 Tacomas & 96-2002 4Runners 2 07-08-2004 01:12 PM
2009 InternetBrands, Inc.
