New Exhaust
New Exhaust
I am looking to put a new exhaust in my 1994 Pickup (4x4, 22RE). My muffler is cracked and i think the cat. is plugged up. I figure while I'm at it I might as well increase performance, so I want a whole new setup, and possibly a header too. I'm on a budget so I just want something practical. My question is if I replace the muffler, cat., and pipes with the same size ones will I have to weld anything or can I do it myself? Also, how do i get the o2 sensors into the system? Thanks for all the help, I really don't know too much about this stuff. Any help, advice, reccomendations, etc. are greatly appreciated.
Id go to a local shop, pick a good muffler like a dynomax or flowmaster and let them run new piping for you with teh muffler and a new cat, be the cheapest way. Then throw down on some headers later.
I'd call that a more redneck thing to do...unless they run straight pipe and weld on a used coffee can to the back and its done on an '87 Paseo or Tercel.
Fink
Fink
Yeah, if you can get the stuff beforehand for cheaper and just let the shop install the pipe and stuff for you. 2.25" is the max to go on a 4 banger without losing too much backpressure.
Originally Posted by nigeltufnel3
thanks for all the help......just one last question......would you reccomend 2.25" or stick with 2"????? Thanks again, i appreciate it.....
well, i called a couple shops and they want like over $200 to install the cat and muffler......can i do it my self, or do i need to weld it up at all.......if i got a new pipe and a 2"->2.25" fitting, could I do it all??? thanks for the help......
$200 is definately too much...it only cost me about $25 as a base price (minus tax, the tailpipe and some other stuff I had done) to get just my muffler put on. It doesn't require anything special to put a cat on as well...just more cutting and welding. I would look for maybe around $60-$100 at the most for the whole thing.
Fink
Fink
