new differential gears breaking-in
Old 12-07-2009, 12:32 AM
KZN185W's Avatar
Hi, Is there a breaking-in procedure that needs to be done if new differential gears are installed? is there a need for a special oil to be used? Thanks!
Old 12-07-2009, 12:34 AM
Elton's Avatar
https://www.yotatech.com/forums/f2/g...ocedure-12588/
Old 12-07-2009, 04:59 AM
mt_goat's Avatar
Yes very important to not over heat the gears. When new, the gear mating surfaces are rough and heat up quicky. If they get too hot it ruins the heat treatment of the gears and they will then wear out faster. I also change the oil often during the break-in.
Old 12-08-2009, 01:18 AM
KZN185W's Avatar
Thank you guys! Appreciate it!
Old 12-08-2009, 02:29 AM
Just Learning's Avatar
ok this brings up a ?what type /weight of oil do you use- i use 85-140, what effect does this have??
i have new lockers and just drove them , yes i did change out the gear oil about 500 miles and i just did it now (trying to figure out how to do the transfer case)
justdifferentials
Just Differentials
09-17-2015 06:14 PM
justdifferentials
Just Differentials
08-15-2015 05:25 PM
Gevo
07-29-2015 11:15 AM
Athansinis
07-27-2015 08:38 AM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: new differential gears breaking-in
