New Alternator... High output... - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-07-2004, 07:50 AM   #1 (permalink)
Ducky's Avatar
How many choices are there for H.O. Alts?
Ive seen the thread about "Excessive Amperage" http://www.excessiveamperage.com and I can get a 200 amp alternator for my rig for $310.00
But I also have seen many get the Mr. Alternator ones
or there's even what Rob has, NWOR's H.O. Alternator for I dunno how much...
What's everyones opinion?
I plan on getting a winch sometime soon, and have all my lights, so I want a bigger alternator and a yellow top optima... Im not planning on doing dual batteries.
__________________
- Ducky
"Stupid a$$ VSC!!!"
www.djducky.com
'01 4Runner SR5 Sport.
Amsoil 2Stage filter, Deckplate, Rear Diffbreather, SAW's in front, OME's in rear, Revtek Diff Drop, BFG Mud Terrain, 4' K40, Cobra 18WX, DRL Mod, ARB Tacoma Bull Bar, 6x Lightforce 170's, Demello Sliders, Sylvania Silverstars, Custom Roof Rack, Viair 450c, ARB Air Locker in Rear, Warn 9.5XP, Optima Yellow, Custom Framerail End's, ORS Manual Hub Conversion, Icom 2720H
Ducky is offline
Old 01-07-2004, 08:08 AM   #2 (permalink)
Senior Member
data's Avatar
Send a message via AIM to data Send a message via MSN to data Send a message via Yahoo to data
Yeah I'd like to purchase one also. That winch sure does bog down everything on pulls.....
__________________
98 Limited 4x4, Rockstomper skid, Rockware Front bumper, Warn HS9500i, 1" RB BL, Tundra coils front & OME HD rear, Nuke quick discos, diff drop'd, 305/70/16 Baja Claws, Electric Locker, couple of battle scars, but nothing major :)
data is offline
Old 01-07-2004, 08:13 AM   #3 (permalink)
Guest
Send a message via AIM to fourunnabilly
Mr. Alternator was great to me. The largest he had for my 4th gen was a 160 amp, but he even overnighted a new plug when we realized the new alternator used an oval one instead of the stock square one...great guy to work with from my experience.
Billy
fourunnabilly is offline
Old 01-07-2004, 08:41 AM   #4 (permalink)
Ducky's Avatar
So it looks like the following for numbers...
Mr Alternator: 150amp ~$235.00
Excessive Amperage 200amp ~310.00
Northwest offroad 160amp ~468.95
This is not including the ~$20.00 harness if you need one.
I dunno, Im sure I dont need 200amps right??? and given the choice of 10 more amps for $233.95 Id go for the 150amp for less...
If I have all my lights and say I had a winch, would a 150amp and a yellow top be enough?
Do I honestly need a 2nd battery? where would it mount? lol...
__________________
- Ducky
"Stupid a$$ VSC!!!"
www.djducky.com
Ducky is offline
Old 01-07-2004, 10:30 AM   #5 (permalink)
Ducky's Avatar
*bump*
Can anyone provide what gauge wire to use, and a wiring diagram or something on how one with a battery and a H.O. Alt sitting on a table would hook it all up?
even if you used ms paint... I won't laugh.... much...
__________________
- Ducky
"Stupid a$$ VSC!!!"
www.djducky.com
Ducky is offline
Old 01-07-2004, 11:25 AM   #6 (permalink)
Send a message via AIM to goatboy22382
I would try wrangler power products at www.wranglernw.com They have some very helpful pdf diagrams for wire gauge v. amperage and things of tha nature in their tech archive.
__________________
94 4runner, v6, auto, 4WD, optima red top, headers and exaust,K&N fipk, 3 in downey lift, manual hubs, 33x12.50 bfg mud terrains, 10lb power tank
goatboy22382 is offline
Old 01-07-2004, 04:25 PM   #7 (permalink)
Bumpin' Yota's Avatar
Send a message via AIM to Bumpin' Yota
if you get the 150amp alt, you can get away with 4ga provided that the run from it to your battery is less than 20feet. Also be sure to upgrade the alternators ground too.
For best results use some 1/0 to upgrade everything. It can be found cheaply at your local welding shop.
__________________
3vze, 4x4, sr5, 90, auto, LSD
2x dB Drag World Finalist
2003 Nopi Nat. Street B champ
2004 SBN Street C champ
2004 SBN Advncd NW Champ
2004 Former WR Holder in NW.
SPL: 159.8db @ 42hz
In loving memory of Jamie Riggs 5/15/85 - 10/8/04
Bumpin' Yota is offline
Old 01-07-2004, 04:55 PM   #8 (permalink)
Churnd's Avatar
Send a message via AIM to Churnd
If you go with Mr. Alternator, get the casing powdercoated. This will help it's efficiency by dissipating more heat. The hotter the alt gets, the less efficient it is. And with that small casing, it gets hot pretty quickly.
Another thing to consider is swapping it in. NWOR will require some fabrication/trimming. I'm pretty sure that excessiveamperage is a direct bolt on. I know for a fact that Mr. Alternator's is a direct bolt on.
You might want to consider swapping in GM unit. They have much bigger housings that can allow for more upgrades without sacrificing performance. Do a search for my user name and alternator. I've been through the trials and tribulations of upgrading. For example:
http://www.yotatech.com/showthread.p...r&pagenumber=2
Hope it works out for you.
__________________
-Chris
If you can't explain it simply, you don't understand it well enough.
Click here to search!
My Website
Churnd is offline
Old 12-22-2004, 07:05 PM   #9 (permalink)
Here's what I did to upgrade my alternator in my '85 4Runner, with pics and wiring diagram and all:
http://www.rocketcityrockcrawlers.co...lt_Upgrade.htm
Thanks,
Al
Albin is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
high output alternator for 1st gen 22re? wifesaysimadumbass Offroad Tech 3 08-01-2006 06:52 AM
How to test a high output alternator Bumpin' Yota 86-95 Trucks & 4Runners 3 03-21-2006 10:38 AM
High Output alternator install. dbikeman 95.5-2004 Tacomas & 96-2002 4Runners 13 04-14-2004 06:24 PM
Alternator output? Phil G 95.5-2004 Tacomas & 96-2002 4Runners 6 01-02-2003 08:32 PM
What's a good high output alternator for a 2nd Gen? JSB 95.5-2004 Tacomas & 96-2002 4Runners 0 10-23-2002 05:46 AM
2009 InternetBrands, Inc.
