New 3rd Gen (again)
New 3rd Gen (again)
Went and picked up a '99 limited 4runner today. Paid $12k for it and there are only 52k on it. Sounds high but that's what they go for here. The best part is when I got there I noticed it has a diff locker and the guy didn't even know what it did lol. But I have a question, I think there's a center diff lock for full time 4wd is this correct? The xfer case stick says 2wd/4wd on one spot then has a button on the side. Anyways, i'll post some pics right away.
my hilux has push button 4wd button on the transfer stick.. then push forward for low....
i was gonna get a 3rd gen but couldnt find one as clean as yours sounds!! they all had 200000kms ++
It's got a saggy rear... I'm thinking an inch or 2 of lift all around might help that a bit. Any suggestions? Getting some new rims and 31x10.5 bfg a/t's for it right away. What should I do engine performance wise? It's mostly street right now which means deep snow and lots of ice where I'm from. Once I've retired my '83 pickup or I buy a newer one this will be for the trails as well.
Pulling the lever straight back will be 4wheel high locked center, from there right and up is 4low locked center. In two wheel drive mode push the button in for 4x4 NOT locked center, aka on road 4x4.
Thanks, that's how I thought it worked just never saw this on any of the other 3rd's I test drove.
Yes, you should stop to engage it. It only works in 4Lo in stock form. However, there is a gray wire mod you can do that will lock it in 2WD, 4WD HI/LO. Search in the tech section.
Without modification, the locker will only engage in 4Lo. If the previous owner did not even know what it was then the odds are they never used it. So it may take time to engage. Also it sometimes help to creep forward and crank the steering wheel a few times.
Big $: TRD Supercharger
Mid $: Cat-back exhaust
Lower $: Seafoam the fuel system, clean MAF, deckplate mod
For many more performance ideas check out http://www.urdusa.com/
e-locker. just use it ten times and loosen it up. no maint required
and use it once in a while to make sure it is loose. if it hasn't
even been used the tolerances are tight and it won't engage immediately
all the time. creep fwd and back and it will eventually !kerClang! and engage
4wd (awd mode) if you have a push button and your
dashboard blinks and then goes to 4 green wheels but
no orange light in middle, you do have the awd mode.
you can leave it in awd forever it you want, it is designed that way
the only 99 was the limited that had this...so yes that is what u got
Hey man, I'm assuming you know all this but I feel obligated to tell ya just in case you don't. I live in Sasktoon too and I had looked at that 4Runner from the dealership on a farm in Dodsland, SK (see my post on this website about this particular 4Runner). I found out that the vehicle was from Red Deer, AB and was stolen once and shows as a total write-off in Alberta. I'm not sure why there was a write-off on the vehicle but there were also a couple of body panels replaced. Not sure how straight the frame is if it was in an accident and written off. There was a "problem with the cluster" and it was changed out so the odometer is only showing 52K but the vehicle actually has 160K on it. The vehicle was bought and sold between several dealers and owners before finding it's last home with you. If you have any questions, feel free to post and I'll answer them if I can. I hope you knew all this and took it into your decision to purchase.
I do wanna supercharge it, probably wait untill next summer for that though. I also have an '83 pickup that will be eating my money for a while too though.
As for wheels & tires, you won't be able to put 15" wheels on there, since they won't clear the calipers without some grinding. You may already know that, but 31x10.50 is a 15" tire size. If you go 2 inches, you can fit up to 255/85/16 (33x10.50) or 265/75/15 (close to 32"), or keep the same tire size you have now.
Be sure and put up pics when you get it done!
It's funny - my 4runner was originally owned in Canada, then stolen and recovered (total loss), then shipped to the US for sale here.
I'm a big proponent of OME lifts. I have the 881 front 906 rear coils, and they are perfect for freeway driving, towing, and they flex really well. Also, you can run stock tires or slightly larger, it's your call. I've heard that Performance Products sells coils that are really similar as well. If you get the OME coils, I recommend getting the matching shocks - they're pricey, but you'll love your rig even more. I got my stuff at toyteclifts.com
I don't want a huge lift or anything I just want it to be a bit more capable and look nicer. The only offroading this will see is when I go camping or fishing and will be mild stuff, I have my pickup for everything else like hunting and trails.
The supercharger will come after a set of headers and a few other bolt-ons. I know bolt-ons usually don't make much difference alone but when I get the supercharger everything together should add up nicely.
What would it take to put a set of heated front seats in?
I didn't know 31x10.5's only came for 15' rims, I wanna keep the tires close to stock I have no plans to regear this. I'm gonna buy tires and rims at the same time, I want some nice black rims. Thanks for the link too I'll be getting my lift from there those prices look good. If I lift 2" is there anything else I have to do? Brake lines or anything like that?
For heated seats, any of your local stereo shops will be able to do that, since you already have leather. Last time, a shop quoted me ~$200 for two seats.
