Neeed Help
Old 09-06-2007, 07:29 PM
Kerby J's Avatar
Question Neeed Help
hey guys i ned some major help with my 3rd gen 4runner, the other day i was startin to put on my lift when i came to a major roadblock. i had it up on jack stands with the tires off and took the bolt off that connects the upper controle arm to the steering knuckle and then i could not get the upper controle arm off at all it wouldnt budge i even took a hammer to it as a last resort. does anyone know of a way that i could get it off? anny suggestions would be much appreciated thanx guys
Old 09-06-2007, 08:59 PM
nc994run's Avatar
Location: raleigh, nc for school chapel hill, nc for home
Shouldn't you be unbolting the lower control arm instead of the upper? That's the way I've done it in the past
Old 09-07-2007, 02:34 PM
Kerby J's Avatar
i might try that thanx for the info i was jus wonderin if there was a way around it caus ei really didnt want to do that but if i have to i guess i will
Old 09-07-2007, 02:41 PM
frodin1's Avatar
What are you installing? What kind of lift? Need more info?????
Old 09-07-2007, 10:03 PM
Kerby J's Avatar
Re
o its a revtek 3 in lift but im only doin the spacer up front for right now cause when i get all my parts for the asin hub swap im doin bout a total of 4 in
Garth schafluetzel
09-02-2010 09:25 PM
azdirtdemon
3.4 Swaps
11
08-14-2010 07:28 PM
brent4R
07-07-2010 10:36 PM
Irish93
08-30-2009 06:47 PM
lilgreg46
04-07-2009 07:13 PM
Quick Reply: Neeed Help
