need your help identifying a noise
Old 04-26-2008, 07:36 PM
derK's Avatar
i have this screeching sound in the rear of my 2000 4runner 4wd and the best way i can describe the sound is a rusty wheel. It resembles the sound of a tee-ter-toter when it tilts from one end to the next, but in this case it's a consistent sound...Here are the symptoms:
1) it is only audible at low speeds approximately up to 30 km/h and from 30 km/h back down to a stop.
2) it DOESN"T get louder when i apply the brakes
3) I'm getting a bit more vibration at higher speeds
i ruled out the brakes because if i know i have to coast to a stop sign i'll switch to neutral and come to a stop....doing that method eliminates the noise but when i put it into "D" and take off again the sound is there. The sound is there as well if i'm in "D" and slow down to a stop.
I'm guessing something to do with my driveshaft?? but what exactly could be the problem??
Old 04-26-2008, 08:10 PM
Mason Dixon's Avatar
time for you to lube your shaft
Old 04-27-2008, 02:29 PM
derK's Avatar
what's involved with that kind of operation?? is there a grease nipple on it?? do i just apply it with my hands??
Old 04-27-2008, 04:08 PM
js9924's Avatar
should be a zerk fitting or whatever they call it on the u-joint it looks like a nipple. might be 2 or more front and back of the shaft. I think
Old 04-27-2008, 05:12 PM
Texas_Ace's Avatar
There are grease fittings for a grease gun on the drive shaft, a total of like 10. At each u joint there are 2 on 1 of them and 4 on the other i think and a few more on teh shatf itself. Just get a grease gun and pump grease into all of them that you can find.
Old 04-27-2008, 05:34 PM
YM13's Avatar
Old 04-27-2008, 05:52 PM
derK's Avatar
Originally Posted by YM13
i'm done exams now so i'll be looking for some pink tacos to do it instead
Old 04-27-2008, 06:09 PM
Jay204's Avatar
baha
Ha Ha Ha...good one!
Old 04-27-2008, 06:39 PM
ciscojay's Avatar
I don't know if a driveshaft would make a consistent screeching sound like you describe. I'd also look at the wheel bearings and *cringe* rear diff. I had the same symptoms a while back and it turned out to be a bad pinion bearing. Luckily fixed for free by the dealership, but I had to fight for it having only 400 miles left on the warranty.
zytra
01-24-2019 03:16 PM
Davebarbier
11-03-2015 03:28 PM
zombie_barbarossa
10-02-2015 10:54 PM
JPV
09-28-2015 03:15 PM
Quick Reply: need your help identifying a noise
