Need URGENT help with gearing??
Old 11-10-2008, 06:56 PM
wmflyfisher's Avatar
I'm highly considering purchasing an 02 4wd Runner this weekend and just got the axle code tonight. Its A03A. If this is true then that means the gears are 138mm, 3.55's right?? Not sure what the last A stands for. The rig has factory 16's with 265/70 tires. Can this be the right gear ratio or am I not looking at something right. If this is true then its probably a deal breaker. Please let me know asap so I can call the deal off if I have too. Thanks in advance. WM
Old 11-10-2008, 06:58 PM
Mic09dcsm's Avatar
Standard or Auto, V6 or 4cylinder?
Old 11-10-2008, 07:00 PM
Sorry v6 Auto
Old 11-10-2008, 07:01 PM
gilby4runner's Avatar
I was under the impression they came with 4:10's. At least that is what is in my 02 sport. Sorry i cant help but heres a bump
Old 11-10-2008, 07:04 PM
Thanks man. 4.10's would be fine with me. I hope thats what it is. Someone help!
BigWavePaul's Avatar
Wink 4.10's = Standard
I thought that 3.55 sounded weird. The code on http://www.brian894x4.com/Gearratiosanddiffs.html shows it's 4.10's 2 pinion open diff- an '02? this sounds like the beginning of something fun...Good Luck!
Old 11-10-2008, 07:17 PM
Thanks guys, Man I was about to flip! I finally found a decent rig and hope to god it doesn't have that gearing. So theres no way possible it came with that gearing correct??
Yeah, should be an excellent build! I'll start a thread when I get it this weekend.
Old 11-10-2008, 07:22 PM
rocket's Avatar
If it has an e-locker it will have 4:30's. No locker = 4:10's.
Old 11-11-2008, 08:51 AM
Rock Slide's Avatar
Rocket's right...And '01 & '02s did not come with e-lockers, so the '02 4wd v6 auto 4Runner you're looking at, without a doubt, has 4.10 gearing.
3.55 is too low a numerical value for gearing on a 4wd v6 4Runner for any year model. 3.90 was a gear option, but not on 4wd v6 autos.
Old 11-11-2008, 09:09 AM
Thanks Slide. Yeah, wish it had an E-Locker but oh well. Would probably never need it anyways! Just as long as it doesn't have anything lower than 4.10's
norcal98
08-10-2015 06:20 AM
Flossy
08-05-2015 05:14 PM
wolfpackfan33
08-02-2015 03:36 PM
justdifferentials
Just Differentials
07-22-2015 08:26 PM
Quick Reply: Need URGENT help with gearing??
