Need some recommendations for lift - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 10-10-2008, 08:14 AM   #1 (permalink)
eburkett's Avatar
I drive a 1995 2.7L 4Cyl Tacoma LX Ext cab(auto). I look to be riding about 70/30 Road/trail&mud. I'm currently running 235's and want to move to at least 33's. I think my truck has 4.10 gears, not really sure. I know i want both a body and suspension lift but need some guidance. I'd like a setup similar to ovvrdrive's truck.
Also, i was talking to a friend about adding a locker( aussie or lockright) to the rear of my truck. He said with our trucks it wasn't possible because our rear diff has a clutch package? Anyone know anything about this our another fix for it?
Thanks
__________________
1995 Tacoma, 2.7L, 4 Cylinder, 149.9k(almost there) and counting...
Quote:
Originally Posted by 94Runner4x4 View Post
an inch is perfect...but hopefully you don't hear that too often.
eburkett is offline
Old 10-10-2008, 08:55 AM   #2 (permalink)
YoterUp's Avatar
Send a message via AIM to YoterUp
to run 33s and clear them on a 95 tacoma you need 3inces of lift i did a rough country 3inch it was cheap i think like 250$ it was just 3inch aluminum coil spacers up front and blocks in the rear id personally do that over a body lift any day i ran 33/12.50-20 mudd grapplers only problem i had was the mudd grappers side lug sticks out alot and rubbed my a-arm by about a 1/4 inch, but that has nothing to do with lift. they make a locker for the tacoma i dont remember which one it is but i know they have one.
heres a pic of my tacoma....
YoterUp is offline
Old 10-11-2008, 08:40 AM   #3 (permalink)
LarsDennert's Avatar
There are plenty of lockers available for that 8.25" diff. A lockrite/aussie will bang and pop a bit back there. A noslip might be quieter but more money.
I'd go with a milder 2" suspension lift with a 1" diff drop and a 1" body lift to keep the geometry better.
That 4cyl will be huffing to push 33"s around on 4.10s.
__________________
Lars
www.LarsDennert.com '99 4Runner, Dual ARB lockers, FJ80 springs and long travel, 33's, Tundra Brakes, TRD Super Charger, Body Armor, Onboard Air, etc
LarsDennert is offline
Old 10-13-2008, 01:39 PM   #4 (permalink)
eburkett's Avatar
whats the largest body lift i could get without having to change cables/cords/hoses/whatnot
__________________
eburkett is offline
Old 10-13-2008, 07:07 PM   #5 (permalink)
red97taco's Avatar
Send a message via Yahoo to red97taco
Hey, where in AL are you from?
Most likely, your truck does have 4.10 gears. But it does not have a clutch pack in it, so you can put a locker in it.
You can go up to 3in body lift, and I think the only main thing it interfears with is the gas tank hose.
I would recomend that you go with a total of 4 inches of lift. You can get a bracket lift, which has a crossmember drop for the front and usually an ad-a-leaf and/or block for the back. OR the cheaper method would be 2in body, and 2in spacer for front and block in the back.
__________________
97 Tacoma, 3.4
6in lift, locked front+rear, NEW 33x12.5R15 KM2's
My Yota Tech photo gallery http://yotatech.com/gallery/showgall...0&ppuser=33148
red97taco is offline
Old 10-15-2008, 10:04 PM   #6 (permalink)
eburkett's Avatar
im from scottsboro, but im attending troy university right now so im down here most of time
__________________
eburkett is offline
Old 10-16-2008, 04:21 AM   #7 (permalink)
crolison's Avatar
Quote:
I wouldn't how about 2" and you trim, thats what I did and I can run 33's easily
I would get some ride height adjustable bilsteins for the front, and some AAL and maybe a new shackle for the rear.
That shouldn't be too expensive and a lot better than a body lift, or blocks and spacers
I would suggest running 255/85/16's or 33x10.5x15 for your tires, they are a lot lighter than the 33x12.5's and you can probabley deal with the sluggishness from the engine on 4.10's, but if your going to regears I would go to 4.88's
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns
armor
locked
lifted
heavy SOB
broken front and rear swaybars
My Profile..
crolison is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Body Lift recommendations TWISTEDTA 86-95 Trucks & 4Runners 18 06-08-2008 08:58 PM
setup recommendations fatdudesurfin Offroad Tech 4 05-11-2005 09:54 AM
Lift recommendations Devildog45 95.5-2004 Tacomas & 96-2002 4Runners 3 02-20-2005 12:13 PM
Shock recommendations for lift Praufet 95.5-2004 Tacomas & 96-2002 4Runners 1 08-10-2004 12:34 PM
recommendations? tigers 95.5-2004 Tacomas & 96-2002 4Runners 3 06-27-2003 09:43 PM
2009 InternetBrands, Inc.
