need some ideas on mounting some switches and gages in an 84 PU
Old 02-06-2005, 03:58 PM
slider_buck's Avatar
right now i just have the gages kinda rigged up where the factory radio was at. i also have a switch for my fan but i will be adding a switch for backup lights along with 2 switches to control my winch. anyone have any pics of how they mounted some gages and switches like i'll have. i've got 2 pieces of aluminum that i'm thinking about cutting so that they will cover the hole where eveything is at right now and mount them in it. what about some gage pillar pics if anyone has any of them.
Old 02-06-2005, 04:27 PM
98LimitedCustomized's Avatar
sure you don't want to have a radio? As far as switches I'd recommend the lighted flip switches that are common, as they only require a drill bit to mount. Otherwise, companies such as Painless Wiring have nicer panels with switches already built in. As for myself, I couldn't live without a radio so I may have some different preferences. I run a 98 4Runner, a pic of the dash might help for suggestions...
Old 02-06-2005, 04:43 PM
yes, i have a radio that will be going below the switches. the switch that runs the fan is lighted. for the winch i will have 2 switches. one of them will be an arming switch with a cover. when i flip it on it will power my in/out switch along with a red l.e.d. that will be mounted by the arming switch.
Old 02-06-2005, 07:06 PM
NorCalVP's Avatar
As for gauges i have a setup similar to Gadget.
http://www.gadgetonline.com/gauges.htm
I only have three mounted below my aftermarket stereo, and not the other three down in the pocket. As for your switches, Why not just wire your Aux reverse lights up to the stock ones with a relay? then you won't even need to add a switch. They'll come on whenever you go into reverse...
Steve
Old 02-06-2005, 07:47 PM
4Crawler's Avatar
How about a 2- or 3-gauge A-pillar pod:
http://www.4crawler.com/4x4/CheapTri...es/index.shtml
Old 02-07-2005, 03:28 AM
Steve
my stock back-up lights don't work. thats why i'm adding some other backup lights. i never really looked into it but i'd say it has something to do with the 350th that is in it.
bigjstang
08-25-2021 12:41 AM
Jonny246
07-12-2015 04:51 AM
jon.r
07-11-2015 03:34 PM
skoti89
07-08-2015 12:05 AM
Gamble_STi
07-07-2015 07:54 PM
Quick Reply: need some ideas on mounting some switches and gages in an 84 PU
