Need some horn help.
Heading for inspection with the 85 4Runner in the morning but my horn sounds REAL low. If I directly connect it to the battery it's loud so somewhere i have a bad connection?? or maybe a relay is bad??
Thanks in advance.
Thanks in advance.
I unplugged/removed the horn and did a quick clean of the plug... then cleaned up the horns terminals and ground/bolt. Also cleaned the fuse on the passenger side fenderwell. Still no louder.
Well I failed inspection for the horn today and a tinted drivers window...so I'll look into the slip ring as well as trace all the wiring.
zytra
01-24-2019 03:16 PM
LotOMiles
09-14-2015 11:45 PM
