need major engine help pleaseeeeee!!!!
Old 10-23-2009, 01:05 PM
fatboidai's Avatar
this is my problem
99 4wd limited toyota 4runner with 235k miles on it here are the problems listed
when i check the code it said my bank 1 and bank 2 is lean on gas and you can smell it from the exhaust. 2 the engine shakes like no other and im loosing alot of power it got better wants i change the spark plugs but yet still has no power what so ever.
so what should i do to fix these problem maybe if anyone from sacramento can meet me up to help me out and give me some advice on this problem i really need to get it fix im a student and i come back and forth from la and i cant afford to have it break down on me
ok one more for some reason when i got my timing belt changed a while back they broke my radiator, they replace it but for some reason when i open the cap it has like red clay stuff inside
Old 10-23-2009, 01:14 PM
gilby4runner's Avatar
1. Check your o2 sensors.
2. Milkshake looking coolant? Check your transmission fluid and make sure its not mixing with the coolant.
Old 10-23-2009, 01:18 PM
fatboidai's Avatar
yeah it like think but its only on the top but yeah umm
so 02 sensor can play a big part of how my cars running then?
Old 10-23-2009, 01:21 PM
i assume the check engine light is on. Take it to autozone and have them pull the code. Search the code that you are given. 02 sensor would be my bet.
Old 10-23-2009, 09:46 PM
brian2sun's Avatar
The red clay stuff sounds like it might be silicate gel from a stop leak type product. How does your oil and your coolant and tranny fluids look?
Old 11-21-2013, 08:53 AM
Mason155lbs's Avatar
02 censor
can some one take a picture of this for me so i can double check if i am looking at the right wire
RaginAsian91
Engine Swaps
03-30-2019 09:17 AM
Seattle_Sign_Guy
07-12-2015 12:38 PM
razorman8669
07-12-2015 12:13 PM
skoti89
07-06-2015 07:45 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: need major engine help pleaseeeeee!!!!
