Need injector help or something with the fuel.
Old 06-15-2005, 08:34 AM
JrodNikls's Avatar
Question Need injector help or something with the fuel.
I have an 87 4runner fuel injected. I have fuel up to the fuel rail but not making it through the injectors. I need a little help trying to find out what is wrong with this. Anyone have any ideas? Any help is appreciated . Thanks
Old 06-15-2005, 09:46 AM
AgRunner06's Avatar
Check your connections or you may have a fried ECU.
Old 06-15-2005, 10:16 AM
Guest
94x4's Avatar
Try disassembling the fuel rail/injector assembly & cleaning everything out with a good brand of cleaner, checking for flow & spray patterns as you go to determine the cause as this sounds mechanical in nature.
Old 06-15-2005, 10:36 AM
callmej75's Avatar
could it be the regulator?
Old 06-15-2005, 11:19 AM
ttr125mar's Avatar
I would first check to see if your getting spark, before you do anything.
Mario
Steven.m.paulk
06-07-2020 10:45 AM
moparbay
10-06-2015 09:24 AM
bradahman
10-01-2015 09:24 AM
themightykhoner
09-18-2015 02:28 AM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: Need injector help or something with the fuel.
