YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-06-2004, 04:05 PM   #1 (permalink)
Send a message via AIM to RufusRunner
need info on replacing stock clutch cooling fan w/ flex-a-lite
I own a '95 4runner, and I'm planning on buying a flex-a-lite metal fan (not electric) but not only do I not know the diameter of the stock fan (the blades got in a fight w/ the shroud) and I dont know how big of a spacer I need. If anyone else has done this, any input would be awesome. Like I said its for a 95 4runner 3.0 3-VZE. Thanks in advance.
RufusRunner is offline
Sponsored Links
To remove this ad, register today!
Old 05-06-2004, 05:10 PM   #2 (permalink)
Bueller...bueller?
Old 05-07-2004, 07:05 PM   #3 (permalink)
any takers? help would be nice...
Old 05-07-2004, 07:21 PM   #4 (permalink)
Guest
hang out for a min and i will run out to measure mine. brb
Yoter is offline
Old 05-07-2004, 07:27 PM   #5 (permalink)
Guest
Ok I measured 2.5 inches from the back of the radiator to the front of the factory fan blades. I measured 3.5 inches from the timing cover to the back of the factory fan blades & a measurment of 19 inches on the fans diameter. Hope this helps yuh. Ben
Yoter is offline
Old 05-07-2004, 07:32 PM   #6 (permalink)
thank you sir.
Old 05-07-2004, 07:36 PM   #7 (permalink)
Guest
Quote:
Originally Posted by RufusRunner
thank you sir.
No problem at all.
Yoter is offline
Old 05-07-2004, 07:42 PM   #8 (permalink)
Guest
In trade for my help will you do me a favor? When you get your parts can you give me a small write up of what you did to swap it and a few part numbers? I might just do this aswell. Ben
Yoter is offline
Old 05-07-2004, 10:05 PM   #9 (permalink)
yeah, If I'm successful, I'll do a write up, but thats a big if. I found a 17" flexalite fan w/ a 1.5" spacer on e-bay for like $20, and from what I understand, a bolt-on kit is the main thing I need to worry about.
Old 05-08-2004, 12:50 PM   #10 (permalink)
yeah, that looks about right, now would that fan and spacer bolt on, or would I need a seperate kit for that?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Fan Clutch: Retrun from Flex-A-Lite TexJJ 86-95 Trucks & 4Runners 0 05-24-2006 11:50 AM
Flex fan question. NOT flex-a-lite/electric fan hockeytown9 95.5-2004 Tacomas & 96-2002 4Runners 4 02-12-2005 03:34 PM
flex-a-lite fan vs stock? jsrusse11 95.5-2004 Tacomas & 96-2002 4Runners 6 09-15-2004 11:43 AM
Flex-a-Lite Cooling Fan 1st Gen 4Runner1988 95.5-2004 Tacomas & 96-2002 4Runners 13 09-09-2004 02:44 PM
Advertising - Privacy Policy - Terms of Use - Jobs
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
