Need Help...Where is the ABS computer and speed sensor located?
Old 08-06-2006, 05:39 PM
soljah's Avatar
Please help me locate the ABS computer and its speed sensor wire on a 1999 4wd SR5 4runner? I have checked my transfer case and I do not think there is a speed sensor on it. I have also looked for a locker harness in hopes of using its speed sensor wire and it appears my 4runner did not come with any locker wiring. If you can suggest another place other than the ABS computer that I can tap into the speed sensor please let me know. Pics or a scan would be greatly appreciated.
Thanks in advance
Mark
Old 08-06-2006, 08:37 PM
petros's Avatar
Well in my '98, when I had the dash all taken apart for cleaning, I saw a module labeled ABS on the driver's side, front/center. Don't know what it was all about, but I'm pretty sure it was labeled a sensor as well. I'd get a pic for you but it's all put back together.
Old 08-06-2006, 08:50 PM
Aetsen's Avatar
Here's a wiring diagram:
ABS ECU behind right kick panel
Speed sensors at each wheel I beleive.
Old 08-06-2006, 09:30 PM
The ABS sensors sit near the end of the axels. Look for thick wire connecting to each sensor sticking into the axel (couldn't find a pic)
Here is a thread on the ABS relay you might find useful
http://www.sonoransteel.com/speedo.html
https://www.yotatech.com/forums/show...ight=ABS+light
Old 08-06-2006, 10:22 PM
BruceTS's Avatar
The grey wire with a blue stripe speed sensor wire you need to tap into is behind the speedometer or at the abs ecu on the passengers side front kick panel.
read this thread
https://www.yotatech.com/forums/f2/need-help-asap-speed-sensor-location-80673/
taller1
11-13-2018 02:34 PM
88sasturbotoy
08-11-2015 01:56 AM
wilbertd
07-06-2015 07:39 AM
karbin
07-05-2015 11:37 PM
Quick Reply: Need Help...Where is the ABS computer and speed sensor located?
