Need help replacing my Radiator.
Hey guys, i have a 98 tocoma, I need to replace my radiator. Do i have to take of my front bumber or can it just come out like that. If some one has a quick run down or how to guide. i will appreciate that.
Thanks
Thanks
The bumper shouldn't be in the way at all. X2 what Elton said, plus the coolant hoses of course, and if it's an auto the ATF coolant lines need to be disconnected.
Should be the same for your's as this 2003 FSM shows: http://www.deserted1.com/FSM/
Do you have a V6?
http://www.deserted1.com/FSM/Repair_.../radi/remo.pdf
For some reason they reference BO-8, maybe you need to remove the grill?
http://www.deserted1.com/FSM/Repair_.../head/remo.pdf
Do you have a V6?
The bolts holding the radiator on are behind the grill. Not sure if the must come off but it would make it easier to get to those bolts:
http://www.4crawler.com/4x4/ForSale/...oyotaRadiators
i did mine on my 98, the grills gotta come off, un hook the hoses, get a new thermostat while your at it, drain it, leave the fan shroud hang on the fan and the four bolts and thats it, easy one man job
TURBOrunnerNM
07-22-2015 11:01 AM
Avenged
07-09-2015 07:55 AM
