Need help installing rancho steering stabilizer !!!!!!!!!!!!!
Old 09-11-2003, 05:58 PM
yoda92's Avatar
Hi Im trying to put this fricken piece of crap on but the bracket is being a bitch. The instruction the kit came with suck . Does anybody have step by step instructions with pictures i could use. Its for a 92 4runner. I took the stock stabilizer off and now i hear i could have left it on . Its trashed now I left it outside and someone threw it away. Do I need it still?Please help!!!!!
Aaron
Old 09-11-2003, 06:30 PM
evilcow's Avatar
How did you get the stock one off? I am having a hard time.
I found this http://www.off-road.com/toyota/tech/other/rs5000_2.htm hope it helps.
Old 09-11-2003, 07:08 PM
Do these stabalizers work better than the stock ones? A noticeable difference?
Old 09-11-2003, 07:13 PM
yoda92's Avatar
to get it off i bought a tie rod seperator got the smallest size i could find and a small sledge hammer banged on it a few times and it poped off. The thing is if you are installing the rancho you will not need to remove your stock one.
Aaron
Old 09-12-2003, 08:35 AM
carpemanana's Avatar
Take the Rancho back and forget about using the brackets... they will slip out over time. Get an OME stabilizer- it is a direct replacement and is STOUT!
delmert
09-30-2015 04:34 PM
Scotto6591
09-01-2015 03:24 PM
Yotadawgjr
10
08-23-2015 10:51 AM
gillesdetrail
08-03-2015 04:43 PM
gmonnie123
07-26-2015 02:44 PM
Quick Reply: Need help installing rancho steering stabilizer !!!!!!!!!!!!!
