need help finding a ground in the interior drivers side....
it is about to dump rain here. i need someone to help me locat a ground for my cb, its all i need to do and im done. I hope i beat the rain! i am mounting it onto the plastic under the steering wheel. SO pref gound is in same location
if you have the plastic piece of the dash that has the vent in it (at your knee's) off, you will see where the bolts go that there are clips with the threads over the holes. i would see if you can put a spade type connector under the clips, so it is touching the dash frame. the bolt should hold it in place once installed. otherwise....use the seat retaining bolt at the front of the seat. a little extra wire, but same results.
i am not a fan of grounds secured to seat bolts. while convenient, this is not the best way.
best way ive found is to remove some paint off somewhere w/ a drum sander attachment (dremel) and screw down with a self tapping metal screw. the area under the shifter is a good area for this method
bob
bob
thanks all, i got it working, well, at least on! I cant get any transmition through the cb other than turning the squelch back and fourth. when i key up to talk, it comes across my basslink in the back???? i did run the wire along with the amp power and rca but i didnt think it would be a problem. also i have the power right to the battery and ontop of the power wire for the basslink...any suggestions? what channel do the truckers usually operate at?
Ideally, you want to run your RCA patch cords down the opposite side of the vehicle as the power wires. Usually the passenger side is the best because almost all of todays vehicles run the majority of them down the drivers side. Secondly, always try to buy the best RCA cables you can. They offer better shielding capabilities. This should clear up your issues.
06-01-2021 01:51 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
