need help fast Biggest tire on 97 v6 4x4 4runner...i searched
friend is needing tires pretty quick and i need to know what the biggest tire are that you can run with his set up
97 v6 4x4 4runner it has 265-70-16's on it now and was looking to get 31's or bigger if possible. no lift of anykind and he wants no rubbing.
i looked throught all the threads in the search and didn't get any clear answers, sorry if i missed it! thanks, critter
If you want no chances of rubbing with the mud flaps still on, the 265-70-16 (31x10.50)is the largest. You can do a 32" tire 265/75/16 but he will have to remove the front mud flaps and the tire will rub the frame at full turn, but only slightly. Keep in mind this is with factory wheels or 4.5" Back spacing on aftermarket wheels.
Hope this helps
Hope this helps
I have a 96 4runner v6 4x4 and i run the 265-75-16. I have no rubbing isues whatsoever. He'll be fine with the 265-75-16 with no mods.
justdifferentials
14
06-11-2017 08:36 PM
83yotastockR
11
11-10-2015 06:54 AM
kbpickens
10-02-2015 03:37 PM
charlie_fong
09-27-2015 10:06 PM
