| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Need help...battery drain
__________________
Preston Edwards 1992 4Runner SR5 V6 4WD (5 Spd.) 246,000 miles & counting 2" Downey coils, 32x11.5x15 BFG A/Ts, Rockcrawler Series 51 wheels, Magnaflow exhaust, Yakima roof rack, ARB bull bar, SAW Torsion bars, (4) PIAA 520s, Cobra 18 WX ST II CB w/ Firestik antenna, hp iPaq GPS 2008 Toyota 4Runner Limted 4X4 15,000 miles & counting |
#2 (permalink) |
The only thing i can say is maybe because you had the doors open all night working on it if the battery was conected the whole time, and possibly you were playing with it for awile after you installed it this could be the reason for the battery discharge but if it charged and then discharged again im not sure. Try seperating the grounds normally you want the same grounding spot at the chassis where the hole is instead of splicing into it but for this application in sure you would be fine seperating all of them.
If this doesnt help your gonna have to go through the whole thing again What kind of alarn is it might i ask? How long did you work on the install? |
#3 (permalink) |
It's a DEI Viper 550 I think. I worked about 5 hours to install it making sure that everything was perfect. I'll try separating the grounds. At this point I would rather buy a new battery if that would fix the problem than touch anymore of that wiring.
__________________
#4 (permalink) |
Im not an alarm fanboy. But, some useful information.
An acceptable amount of battery drain is Less than 50 milliamps. Anything more and youll have trouble.
__________________
Jay 98 X-Cab Tacoma 3.4L Manual Trans. | TRD Fender Flares | Weld Wheels w/ 31 x 10.5's Jason Larsen Master Diagnostic Technician - Beaverton Toyota (Portland, Oregon) Wendsday - Saturday by appointment only. (503)626-7200 (ask for me by name) |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Slow drain on battery... | Q-DawgVFR | 95.5-2004 Tacomas & 96-2002 4Runners | 13 | 03-01-2007 10:20 AM |
| HELP! Battery drain! | Sporin | Maintenance & Repair Archives | 10 | 07-01-2005 05:24 AM |
| will i drain the battery? | InFlames | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 06-06-2005 10:35 PM |
| How to check for a drain on battery? | 86toyota | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 03-07-2004 02:14 PM |
| Mysterious battery drain | deadrunner | 95.5-2004 Tacomas & 96-2002 4Runners | 10 | 10-21-2003 07:40 AM |
