Need Help With Automatic Hubs!!!!
Old 11-07-2005, 05:52 PM
pullnshoot25's Avatar
I have a 1989 toyota v6 4x4 with the ADD system in it. Right now, I have to replace my differential. My truck is mostly disassembled and all I need to do is remove the CV shafts... but in order to do that, I need to remove the hubs. SInce they are ADD hubs, they are different than the automatic ones... HOW do I remove these hubs? Need help desperately.
-Nathan
Old 11-07-2005, 06:02 PM
AW1090's Avatar
search a bit...there are tons of threads on this.....I think 4x4wire has a full write-up on this also
Old 11-07-2005, 08:47 PM
runethechamp's Avatar
Use a hammer and screwdriver to get the brass cap off the flange, take off the axle bolt and washer, unscrew the nuts holding the add flange in place, use a brass bar and a hammer to get the cone washers loose, use two bolts in the available holes to get the flange off if it doesn't come by itself.
Old 11-08-2005, 01:15 AM
leebee's Avatar
pick up a haynes or chilton manual and follow the directions. as champ stated above, its a 1 banana job.
lee
Truckwithoutaname
10-03-2015 03:41 PM
bradahman
10-01-2015 09:24 AM
tshort48
09-27-2015 01:04 PM
Toys4parts
09-26-2015 01:56 PM
toyhaulert100
09-24-2015 07:55 PM
Quick Reply: Need Help With Automatic Hubs!!!!
