Mysterious Wire - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 05-09-2007, 04:00 AM   #1 (permalink)
kevin444's Avatar
Send a message via AIM to kevin444
Mysterious Wire
Im in a middle of a sound deadening project, similar to Bob's Writeup of sound deadening project outlined in his awesome site www.4runners.org.
Anyways i accidentally snapped this wire and i have no idea where to reconnect it so i can repair, solder it and heat shrink it. This wire initially was tape and lined to straight across the trunk. The wire begins from the tail light controller box in the rear driver area. Right behind of the driver side tail light. The end part is where i'm lost or possibly blind. I cant seem to find the it's respective connection point. I don't see any wire shards or whatnot.
Enclosed is 2 pictures of the wire in question.
Thanks for your help guys.
__________________
02 4runner conversion complete!
kevin444 is offline
Old 05-09-2007, 12:01 PM   #2 (permalink)
kevin444's Avatar
bummp
__________________
kevin444 is offline
Old 05-09-2007, 12:03 PM   #3 (permalink)
OSU4Runner's Avatar
Send a message via AIM to OSU4Runner
Do your taillights still work? I doesn't look like anything is coming out of that insulation. Did you cut it back and see if the wire was broken or capped off?
__________________
2006 Tacoma SR5 - Stock for now
2000 4Runner Limited
16x8 Pro Comp Steelies wrapped in 285/75R16 Pro Comp M/T'S~RB 2" Body Lift~SS 1.2 Lift~1st Gen Roll Bar~Surco Safari Rack~ Trail Gear Sliders~Deckplate Mod w/ True Flow~Satoshi Grille~Hayden 1678 Aux Cooler~Safari Snorkel and a bunch of other crap.....
OSU4Runner is offline
Old 05-09-2007, 12:05 PM   #4 (permalink)
OSU4Runner's Avatar
I would check everything on the rear of the truck. From your rear window, blinkers, reverse lights, etc etc. If everything works......screw it
__________________
Old 05-09-2007, 12:09 PM   #5 (permalink)
washer fluid for the rear window?
__________________
69' FJ40 "RUSTY" H41,3 speed case, ARB Lockers F/R, 34x9.5 TSL's, Co2, Warn 5687, 2.5 " Parabolic lift, Pertronix Ingitor, 4+ U bolt flip kit, 20 gal. Aux Tank
2000 4-Runner SR5, V6, 5 speed, Highlander edition, S/C, URD 7th, DP
TLCA #14752, L.A. Trail Crew
Phi Kappa Psi
http://www.marksoffroad.net My Parts Source
Ian Rogers is offline
Old 05-09-2007, 12:28 PM   #6 (permalink)
kevin444's Avatar
Yeah my psgr tails are not working braking wise. But i Its only one wire inside the insulation. However the wires leading to the psgr tail light appear to be fine.
__________________
kevin444 is offline
Old 05-09-2007, 12:29 PM   #7 (permalink)
seanz0rz's Avatar
Send a message via AIM to seanz0rz Send a message via MSN to seanz0rz
thats what it looks like to me, but it should just go straight up the right side of the vehicle, not across the cargo deck.
the washer fluid is the brown looking line in the second pic, just below the rear window.
i would make sure all your rear lights work, brake, parking, turn, reverse.
also check the hitch wiring harness for those things. it might be part of the harness for the hitch.
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, 1" 4crawler body lift, etc.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Mysterious black box TRunner 95.5-2004 Tacomas & 96-2002 4Runners 23 10-04-2006 06:58 PM
Mysterious buttons smiljko 95.5-2004 Tacomas & 96-2002 4Runners 8 11-03-2004 12:21 PM
Mysterious battery drain deadrunner 95.5-2004 Tacomas & 96-2002 4Runners 10 10-21-2003 07:40 AM
My mysterious oil change.... AgRunner06 Off Topic Talk 7 08-20-2003 12:15 PM
2009 InternetBrands, Inc.
