| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Mysterious Wet Spot
__________________
98 SR5 V6 4x4: OME 3", 285/75/16's, ARB, Smittybuilt XRC8 -Chris |
#2 (permalink) |
Possibly the windshield. My truck leaks on the passenger side when it rains and soaks the carpet.
__________________
89 Pickup, 22RE, 5 spd, 175XXX |
#3 (permalink) |
sounds very likely now that you mention it. thanks man, i never woulda thought of that
__________________
#4 (permalink) |
also check the grommet where all of the wiring from the engine bay enters the cab.
__________________
04 taco, 3.4 5spd. loads of goodies, FZJ80 axle SAS in progress. 85 pickup, 327sbc, truggy, in progress. 86 mazda b2000 street queen haha. 92 mazda B2600i 4x4 absolutely mobs. 81 ford bronco drinks gas 90 mazda mx-5 all original. when in doubt, tach it out. |
#5 (permalink) |
I just removed my whole interior (dash, carpet, wiring) yes, everything. At the top of the kick panel (where it meets the cowl) there is a very small hole. I'll be fixing this and some surface rust. This may be your source of water. I thought at first that my windshield was leaking also. I don't have any pictures, I can take some if you want.
(I didn't remove the interior to find where the water is coming from. This is my project truck). |
#6 (permalink) |
89dlx: pics would be great if you could. i want to get this thing squared away fast! thanks for all the help and suggestions
__________________
#7 (permalink) |
I have this problem with my 96 limited also, I'm thinking it might be one of the drains for the sunroof came unhooked
#8 (permalink) |
on my 99, when i wash it or it rains, on the very top left corner of the inside windshield there'll be a couple drops.
gonna get on that
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#9 (permalink) |
This is the passenger side kickpanel. You can see the rust at the body seam.
![]() This is the same area but from the outside (fender removed). You can see the little hole that is there. ![]() It looks like the factory used some kind of foam to seal the seam, then they sprayed the paint over it. Any water will make this rust fast. My windsheild may in fact be leaking. I'm going to pull it out (needs to be replaced anyways) and see if there are any other rust holes. I'll be fixing them with the floor/trunk kit from POR15. |
#10 (permalink) |
Has anyone found the fix for this? I had a wet floor this morning after my 4runner was parked all night. I'm think its the sunroof, the windshield or the drain for the grating by the windshield wipers.
#11 (permalink) | |
Quote:
well gee you give us 3 mystery sources not confirmed...since you haven't isolated the problem, how is there a fix ? the fix is get your butt in the vehicle and pinpoint the cause |
#12 (permalink) |
See my version of this fun chore:
http://www.yotatech.com/f116/sprung-...coming-139455/ |
#13 (permalink) |
I had a similar situation but it was my seat that was getting soaking wet. I don't have a sun roof either. As it turns out, the roof rack mounts (i don't have a roof rack either, just the plastic "trim" peice) were leaking. Took them off, clean and resealed with silicon.. no more leaking. Hope this helps, good luck!
__________________
'98 4-runner, 5-speed, 3.4, e-locker & leather. Deckplate, Toytec 3" OME 881/891, Locker mod & 285/75/R16 Mud Kings. |
#14 (permalink) |
I had the same situation but my fix was very much different. My driver's side floormat was soaked after driving in the rain (like what was stated) except I could not find any trail of wetness anywhere. It turned out to be one of my body plugs was leaking from the outside. It leaked so much so that the carpet was getting moldy. I took out my body plug and filled it with silicone sealant and called it good!
__________________
00 SR5 with plenty of bedliner,flowmaster offroad 40 pipe,engine mods,breathers relocated, TJM T-13, Armorology tire carrier, bushwacker flares, trailgear sliders, optima yellow top... Just keeps going!---Soon to become a SAC! |
#15 (permalink) |
First post with my new ID.
Wow, same problem I have been having. Several years ago, the passenger side was getting wet. It turned out to be that the A/C drain was clogged. Now, the driver side is wet. I havent had the time to try to figure it out. I guess I will try to use some of these suggestions. (I used to hang out here a lot several years ago. But since I changed my main ride over to a Nissan, I didn't have the time to drop in. Finally getting rid of it, so I am back!)
__________________
'09 Tacoma DC '06 X-Terra - gone '99 SuperHawk - the new toy '99 9.3SE Viggen 'vert 5sp '98 4Runner SR5 3.4 auto '78 280Z - sleeping |
#16 (permalink) |
Ok,
I got around to taking a look yesterday and found that the person that installed the fog lights pulled a grommet out there seems to be a water trail that goes down the firewall and probably into the hole. I pushed the wires to the bottom of the hole and put the grommet back in. My carpet is still pretty wet so I may have to pull it up so it can dry. |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| mysterious substance | camo31"10.50" | Pre 84 Trucks | 5 | 05-10-2008 07:07 AM |
| Mysterious Clanking, got help? | juddemt | 03+ 4Runner/GX470, & 05+ Tacomas | 5 | 09-16-2007 08:06 PM |
| Mysterious Wire | kevin444 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 05-09-2007 12:29 PM |
| Mysterious buttons | smiljko | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 11-03-2004 12:21 PM |
