Is my transmission gone?
CEL code PO770 (shift solenoid E malfunction)
So guys is my transmission gone or is it even my transmission? any words of wisdom will help
long story short, I think I overfilled my transmission fluid by a lot and drove it with it overfilled for 2-3 months.
been noticing slipping for the past month, it slowly got worst..but was definitely still drive-able.
Yesterday I put the car in Reverse and backed out...but the car had a really hard time going in reverse. When I put it to Drive, I noticed it wouldn't budge, but I had to pump the gas a bit for it to get going.
Ever since then, its been pretty rough...stop lights take a lot of gas to get going (pumping the pedal, or else it just makes loud noises at high RPMs). Rolling on highway at 70 i dont notice much, but stop and go traffic hurts.
I cannot reverse the car, I will put in reverse and it will either stand still or it will drive FORWARD. Neutral gear does the same thing.
PO770 code came on a while ago. (shift solenoid E malfunction)
is this a part I can replace???
Thanks guys
Thanks guys
According to my 1999 FSM, that code could also mean a bad valve body, or bad torque converter. Hopefully it just the solenoid. There is a test for the solenoid to see if its bad, once its removed.
TheBFA
02-15-2020 06:55 AM
Odin
09-26-2015 06:56 PM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
