Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
__________________
1994 4Runner SR5 2WD V6 auto Tires: 225/75 R15 Michelin LTX (next to upgrade) Sound: Alpine, JBL speakers, Blaupunkt amps and Boston Acoustics subs (along with Dynamat) Security: Clifford alarm NEW: Downey HD/Bilstein & window tinting |
#2 (permalink) |
Personal
Sales Rating: (0)
Hopefully it's something stupid and simple like sparkplugs. Mine went out on me - all of a sudden. It had the same symptoms as yours. I just put in some new plugs, wires, and a cap and rotor and she ran just fine after that. I would try that first before putting any real $ into it.
__________________
95 4Runner, 3VZE , 141k, 4WD, Auto. (Head gaskets replaced at 106k) |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
Well - I have those Bosch Platinums in there - so I picked up some NGKs - hopefully that will help. I think this is just a sign that I should do all that maintenance I have put off. At least I didn't have to walk home
__________________
#4 (permalink) |
Vendor
Sales Rating: (0)
did you get the ngk std plug or the v power? the v power is actually the specified replacement in the toyota manual....
also, try the fuel filter and running higher octane gas, i had some issues with my truck and did both those things and it runs better than it ever has before |
#5 (permalink) |
Personal
Sales Rating: (0)
You could have a bad load of fuel.If it started after refilling the tank.
#6 (permalink) |
Personal
Sales Rating: (0)
[OP]
I picked up the NGK v-power plugs.
I use 87 octane - and I try to use Shell gas (it has worked well so far) - I actually had about a half tank so it wasn't completely empty. I woud like to think that the gas station by my house doesn't cut their gas with water - especially since we are paying so much per gallon
__________________
#7 (permalink) |
Personal
Sales Rating: (0)
You didn't put diesel in, did you?
![]() Hope you get it figured out. As mentioned above, I'd take care of all the simple things first, which never hurts, then move onto bigger issues.
__________________
-David '98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops '73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top. TLCA#14428 |
#8 (permalink) |
Personal
Sales Rating: (0)
[OP]
ha! I didn't put deisel in - but maybe I can try to swap in some glow plugs instead of NGKs to see if it helps things.
I took Stewie (my 4runner) to the shop this morning - it was still idling not so good - so at least the mechanic could hear it an action. It was also strange b/c it took forever for it to warmup (via the temp gauge). To make things more interesting, I noticed my "seeping oil" might be more of a "leaking oil" on the front passenger side - strange b/c there is actually oil on the suspension from this leak. I am very excited. I think if it's going to cost me over $1K - I will hold off and look into doing an engine swap
__________________
#9 (permalink) |
Personal
Sales Rating: (0)
Have you checked the level of antifreeze? Has the head gasket been worked on before?
__________________
#10 (permalink) |
Personal
Sales Rating: (0)
you got off easy, mine is dead.
__________________
--Brian '94 4Runner SR5 4WD 285 Terra Grapplers on FJ80 wheels|Rancho 9000s on all 4 corners|Cruiser coils|Marlin Rear brake line Stereo CDT Audio CL-61A|CDT Audio CL-6X|Profile 640 and Profile 600M|Audiobahn 100Q |
#11 (permalink) |
Personal
Sales Rating: (0)
[OP]
NICE!
The headgasket was done under the recall at 70K and it has the "gurgling" in the heater core - but it hasn't impede the rocket-like performance that the 3.slow is known for. So the mechanic called - one of the spark plug wires had a higher than normal resistance - swapped it out and it seems to be idling fine. So it looks like the usual tuneup will be in order. Although I put in NEW BOSCH spark plug wires about 6 months ago - so I will definitely not be using them again (the Toyota OEMs will do nicely). He will also be replacing the timing belt/water pump - and once he gets into the engine more, he can check on the phantom oil leak. I think the best part was the mechanic calling me up and saying "Your engine's dead bro" - to which I just kinda laugh since that would just be my luck on a monday. He then said he was joking and told me the whole schpiel. Good times when your mechanic can toy with your emotions like that...
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| sick little runner | twitchee2 | General Vehicle Related Topics (Non Year Related) | 5 | 04-13-2007 12:16 PM |
| sick s.o.b | UNLIMITED96 | Off Topic Talk | 15 | 08-10-2005 02:43 PM |
| Sick, sick, sick! | scott.475 | The Fab Shop | 17 | 01-13-2004 09:15 PM |
| Help Runner is Sick :( | boo204 | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 06-07-2003 12:21 PM |
| I have a Sick Runner adn need some help | boo204 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 02-05-2003 04:04 PM |
