my runner is having trouble starting
Its definitly not my starter because it cranks strong but the motor justh as a hard time getting going. IT takes a LOT of cranks when its cold it doesnt just fire up...also when its cold and starts up finaly it barely is turning over and it just slowly rises till 4-500 RPM
the weird thing is i recently had my timing belt, water pump and all the other accesory belts replaced by a pro. mechanic and he didnt find anything wrong..
im thinking maybe i just need to turn up my idle adjutment screw because it really is idleing low....
thanks for the help
thanks for the help
cold start injector? cold start injector time switch? first thing check your connection to your cold start injector. My wiring harness from my cold start injector came loose...then I snugged it up and it would start within 2 seconds every morning.
Originally Posted by 89macrunner
hmm where is that located??
anybody have pics?..or a simple how to would be great.
http://personal.utulsa.edu/~nathan-b...88coldstar.pdf
http://personal.utulsa.edu/~nathan-b...ne/97colds.pdf
