my power windows
Originally Posted by WIZARDOFODDZ
won't work. I tryed everything. My back window works most of the time, but the passanger and the driver side window won't work, Any ideas?
Originally Posted by doink
perhaps a bit more info as far as what type of vehicle you have will speed up the number of replies.
I have tested all circuits with a test light, NO power.
I have 214000 miles on my baby and I don't want this to be the end. Is there a relay of some sort, if so where?
Sorry, it's a 1987 4 runner
Good luck,
Nam
Nam
I have already searched the wiring diagram. It shows a power window relay, but it's not there. I live in upstate New York, not someplace you want your windows stuck.....LOL Up or down.
It shows a relay next to the manual brake handle, nothing there????
I also called a couple of dealers im my area, no one seems to know. My next post may be in the classified area :con
Mossback74
Originally Posted by Mossback74
Are you getting any power to the switches?
This is going to suck, I can't believe the cost and who knows where and when it I'll get it.
It's D6 - see if this helps.
The objects next to it are A12 Antenna relay and O10 Overdrive relay.
Assuming you started with the fuse?
Assuming it is indeed a bad control relay - if you cannot find a cheaper source for a replacement, if you wanted to you can wire around it quite easily, or put in a $4 simple relay. All the "control" relay does for all that money is give you the time delay after the ignition is turned off. It simply feeds power on/off to the window switches, but has a 60 second "off" delay. Nice feature but not worth $300 to me!
Seems on the later 1st gen Runners they use a Power Window Module not a relay, Toyota wanted $419 Cdn plus 15% Tax for this puppy. (Stupid Stealerships)
FIX:
Run a power line from the battery with a 30AMP fuse, into the door. Splice this Power line into the Blue Wire with Red Stripe (Located: Drivers Side Window Switches)
This Bypasses the Power Window Module all together. The neat part is that the windows will go up and down with out the key in the ignition.
FIX:
06-01-2021 01:51 PM
FS[PacNorWest]: 1987 Toyota 4Runner $1800 Whidbey Island, WA
coreyedwards7611
01-16-2016 06:38 PM
Johntom240
7
07-13-2015 12:18 AM
