My new tires/wheels/lift
Well, I finally got it at least presentable. In the near future will be a 1" BL, an alpine x001 deck, and bumpers. I just put the wheels and tires on and am planning on selling the oem sport wheels if anyone is interested... They will be in the classifieds section shortly, maybe even today. It all depends on how ambitious I'm feeling. I'm extremely happy with how it looks and drives except for the bad balance job the tire shop did. Anyway, let me know what you all think.
And before the wheels and tires
The bighorns are awesome. They ride ten times better than my old bfg at ko's and they were cheap! They are 255/85/16 and yes, a little rubbing but only when turning at compression. I'm planning on a 1" body lift so that should take care of some of that. They seriously soak up bumps a lot better than my old tires at the same psi so I'm happy.
looks great i am too looking into the 255/85 era when my time comes. where did you find the maxxis buckshots everyplace around here says ill have to order them offline somewhere (if you did this from where?)
On summit they say they only have 16x7 in our bolt pattern but when they came they were actually 8 inches wide. Oh, and the backspace is 4 inches.
I'm running the stock tundra shocks
Do you have the 4.56 or 4.3 gearing? I thought about doing with larger tires-but the 4runner already wheezes with stockers and 4.3 gearing. If there were a economical way to upgrade to 4.56, I would without losing the rear locker.
...you might have 4.10 gearing as well? It seems pretty uncommon to come from the factory with 4.56 gears, but, they did do it.
I got 4.30's and run 35's w/o problems.
