My new Lift!!! YAY!
My new Lift!!! YAY!
Welp, Thanks for everyone's advice, especially Gene and Rob... Finnally got the OME and SAW suspension setup on with the help of Jowie...
Here's the Hotrod pic... Without the front suspension done...
And heres with the SAWs installed...
Ugh... with another few things off my list... time to start saving for the next item, then the next... and then the.....
Ducky
Ducky
265/75/16 BFG Mud Terrains....
Very nice tire... of course, I have yet to get them muddy... just need to get a few more things before I can take it offroad... (brake lines mainly)
Ducky
Ducky
Duck:
I just did my lift a few days ago and was wondering...
How much thread do you have showing between the collar and the bottom of the shock in the front on the SAW's.
Also are your fins on your CV's touching a little as well.
-Dave
-Dave
It differs.. unless im wrong.. its late and raining, but its near 2" on the passenger side and near 3" on the drivers.. i think ill check that sometime after it settles... Im sure its level, we measured each side from the wheel up to the fender...
and it does look like the fins of the CV boot is touching..
Ducky
Ducky
Re: ...
Ducky
Ducky
Originally posted by DSP
Duck:
-Dave
Duck:
-Dave
Originally posted by keisur
not to but-t in but I have 84mm of thread showing on the pass side and 86mm on the drivers side. I measured in metric because my scale was easier to read like that. I do have fins touching, majorly. here's a shot of the wear. I have a closer pic if you need to see better. after a while it will wear through. that's when it'll be time to do the ORS manual hub conversion.
I guess I am a little confused on the manual hub swap.
I have read this a little in some previous threads but when i search by "cv boot" or"cv" anything for that matter the search engine tells me that the word does not have the minimum 3 characters.
Anyway, When the time comes and your CV is torn or leaking or making noise, etc. why switch to the manual hubs and not replace the CV Boot and joint.
Is it expense? And correct me if I am wrong but, once the manuals are in...you can never shift into 4wheel on the fly again. Correct? I mean you always have to get out, turn your hub and then get back in the car.
Can someone shed some light on this conversion for me.
Thanks
Dave
Is it expense?
Is it expense?
Thanks
Dave
Thanks
Dave
check it out:
Manual Hub Conversion from ORS
