my new 2000 4runner what kind of service should I have done
Old 05-11-2007, 06:57 PM
linkovich's Avatar
I finally found and bought a 4runner locally. Its a 2000 limited 4x4 with the diff lock. It has has 95,000 miles. My question is what kind of service stuff should I do right now?
Old 05-11-2007, 07:30 PM
Knuckles's Avatar
Search it, Its been Covered So many times.
Old 05-11-2007, 08:35 PM
Mason Dixon's Avatar
I've got the same ride. Knowing what I know now, I would(if your mechanical), pull off the tranny pan and clean it and the filter....replace your rear inner axle seals with napa seals(make sure the napa seals are green around the outer edges), grease your drivetrain ujoints, put the beefier tundra brakes and calipers on the front....i'll update as I find stuff to be fixed!
Old 05-12-2007, 09:24 AM
linkovich's Avatar
I did search and didn't really find what I was looking for
Old 05-12-2007, 09:25 AM
linkovich's Avatar
Thanks Mason!
Old 05-12-2007, 09:26 AM
drguitarum2005's Avatar
Location: Houston (home), Atlanta (school), Cincinnati (work)
what kind of maintenance was performed prior to you getting it? knowing that would help out a lot...
Old 05-12-2007, 10:37 AM
Texas_Ace's Avatar
Don't let them scare you, they are just grumpy.
The search on this site is totally screwed up, I have been using it for a few months but i still can't even find threads i KNOW are there, even ones I posted. Just try searching but here is a thread i had about the same thing...
https://www.yotatech.com/forums/f2/what-should-i-do-what-should-mech-do-my-200-4runner-113162/
Old 05-12-2007, 12:11 PM
linkovich's Avatar
Thats my problem. I bought it as a trade in from a dealer and there were no records with it. I had Toyota check it out and everything came back good. I was just trying to find out any things that toyota may not check very throughly.
I'm going to do most of the stuff that is recomended for the 90,000 mile service.
Old 05-12-2007, 12:12 PM
linkovich's Avatar
thanks texas ace, that helps a lot
Old 05-13-2007, 02:29 PM
pius222's Avatar
Congrats, that's the first thing I thought about when I got my used 99 SR5 in March. Maybe the car is in good condition, but I just feel there must be something that can be repaired since it's a used vehicle. my toyota dealership told me to bring it back when I get my 1st oil change.
Old 05-13-2007, 02:39 PM
nieuwendyk-25's Avatar
https://www.yotatech.com/forums/showthread.php?t=113162
Texas Ace is correct, I have had the same problems searching for ones I know are right here. Welcome to yotatech, and don't worry about the grumps.
Old 05-13-2007, 06:21 PM
linkovich's Avatar
I'm not worried about the grumps, every forum has them...I guess its just a fact of life. That for all of the comments guys!
Old 05-13-2007, 06:33 PM
Texas_Ace's Avatar
No problem that is what we are here for.
Old 05-13-2007, 06:36 PM
pattycakes77's Avatar
i thought this was helpful, found it in the write-ups section:
https://www.yotatech.com/forums/showthread.php?t=76317
deals with fluids mostly but also mentions some other helpful things to check down the line, and with 90k it's stuff you might want to look at.
when i got my '98 at 62k i had the coolant flushed for starters and i'm in the process of converting over to all amsoil synthetic fluids. i'm putting my tundra breaks on in a couple weeks and i'll flush out the breaks with new toyota fluid when i do it. i'm not a mechanic so i'm sure there are plenty of other things to look at drivetrain-wise, but also check your belts and hoses just to be safe. just a few things off the top of my head.
patrick
mskalmus
05-28-2017 07:51 AM
Avenged
07-09-2015 07:55 AM
Cplmike
07-08-2015 08:47 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Jnkml
07-06-2015 01:20 PM
Quick Reply: my new 2000 4runner what kind of service should I have done
