Is my fuel pressure regulator supposed to do this?
Old 07-17-2005, 04:48 PM
AgRunner06's Avatar
Question Is my fuel pressure regulator supposed to do this?
I've suspected my fuel pressure regulator of being faulty ever since I swapped my injectors. So I unplugged the vacuum hose from it and took it for a drive to see what it would do. Much to my suprise, it had NO effect on how the vehicle ran and drove (except for the slight increase in idle from the vacuum leak). Is this correct? I thought for sure it would have problems getting up in the rpms but it didn't. I'm stumped.
What do you guys think?
Thanks
Old 07-17-2005, 05:50 PM
hondavxr's Avatar
Was there actual gas or fliud coming out of the hose when you took it off? If there was then your fpr is broke. When the fpr becomes defective it shoots the gas back into the manifold thru the vaccuum line. Check your fuel filter it might just be a little clog.
Old 07-18-2005, 09:04 AM
AgRunner06's Avatar
No there was no fuel coming out of it.
The reason I ask is that my fuel system was subjected to some high pressures of about 75psi during a botched-up fuel system cleaning. The result is a hesitation only after the vehicle has ran and then cooled to a certain temp. My TPS is adjusted correctly, fuel filter has been replaced, injectors swapped, and fuel system cleaner has been used with no luck.
Can someone with a 3.0 unplug the vacuum hose on their fuel pressure regulator and take a quick drive and let me know what happens? It would be VERY much appreciated.
Thanks
Old 07-19-2005, 08:58 PM
AgRunner06's Avatar
Anyone else?
Old 07-19-2005, 09:20 PM
DudeBud's Avatar
nothing happens
Old 07-02-2010, 10:13 AM
dvillano's Avatar
hi guys,dont mean to hijack but,when i remove the vacuum line,nothing happens,idle dosent change no vacuum from line,any idea what could be???
jbv808
08-06-2021 04:47 PM
Doug4320
03-24-2018 10:11 PM
Poppie51
07-23-2015 05:03 PM
v_man
07-23-2015 04:01 PM
Poppie51
07-16-2015 06:16 PM
Quick Reply: Is my fuel pressure regulator supposed to do this?
