My First attempt at a brake job, 5 hours later, im not even 1/2 done
Well I began my venture into installing my own brakes today.
This was not just a pad replacement (which I now know is easy as can be), this was supposed to be an upgrade from the 15" model brake system that came with my 96. So I bought calipers from the newer 4runner and I have the rotors and pads ready to go.
To get to the bottom of things, I cant get the rotor off of the truck... I have WD 40d, Hammered, Pryed, and done everything in my power to pull them off. I don't know what else to do. I dont know if there is a mobile mechanic that could help me pry these beasts off. But maybe someone out there has some 1st hand experience in gettin of these heavily rusted rotors.
Use some PB blaster on it (soak it 3-4 times about every 20 min or so) and then just let it sit for another hour. When you come back, use a 2.5 lb sledge to hit the rotor off from the inside out (hit it on the inside right where the caliper bolts on). Keep spinning the rotor by hand and hit it about every 90 degrees per revolution. It should eventually come loose.....it's alot of elbow grease to work with rusty parts for sure.
BFH and PB Blaster, absolutely worked... now... for some reason I cant disconnect the caliper from the brake line.
I took an open ended 10mm wrench and turned it... nothing... any tips? Im going to soak it in PB, and try again after i get back from the gym. Any tips are appreciated.
If and when I get the bolt loose, should I be watching my master cylinder for fear of it running dry? or will i be able to stop the flow of Brake fluid with my thumb or by jamming it into the new caliper?
Shirley, I think you and I were talking about different things...I was talking about the bracket bolt that holds the rubber line to the steering knuckle....sounds like you are talking about removing the brake line itself at the caliper. To answer your question, yes, you should watch the master cyl and do not, under any circumstances let it run dry (it is best to have a couple 5-6 bottles of DOT3 fluid around just in case and for bleeding later). Can you stop the fluid with your finger? Yes, just about anything you can get to fit tightly will stop the fluid from coming out.
If there is a rubber hose upstream of the bleeder, put a clamp or locking pliers on it. Do not use an open end on the bleeder - use a box wrench...
So I strippped the hell out of the bolt on the back of the caliper. I have a feeling maybe I was skipping a step or doing something retarded, but now I need to replace the metal line between the caliper and the MC, I need to replace it.
I'll be doing A Tundra Brake Upgrade tomorrow on my 97...
