my ((brake)) like wont go out. :(
Old 12-22-2004, 11:43 AM
ken.vs.ryu's Avatar
Angry my ((brake)) like wont go out. :(
i have the handbrake fully disengaged but the light is still on. it's not as bright though when it's engaged.
Old 12-22-2004, 11:45 AM
SLC Punk's Avatar
Is your brake fluid low?
4Hummer's Avatar
Check your Brake Fluid ?
Old 12-22-2004, 12:39 PM
steelhead's Avatar
May also be time to flush your brake system!
Old 12-22-2004, 01:04 PM
Yamaha+Toyota=Fun's Avatar
Did anyone say brake fluid?
Old 12-22-2004, 02:14 PM
colsoncj's Avatar
Check your alternator.... I know it may sound weird, but when my alternator when kaput, my brake light wouldn't go off... if I remember, somewhere, somehow in the wiring they are connected. But mines an 87 22RE, slightly different from yours.
Old 12-22-2004, 04:15 PM
Mad Chemist's Avatar
Did someone mention brake fluid?
Old 12-22-2004, 05:24 PM
Tacoma Dude's Avatar
None of these guys know what they're talking about... check your brake fluid!
Old 12-22-2004, 10:42 PM
humanoid's Avatar
Did anybody mentione to check your brake fluid level? But seriously, check your brake fluid level though.
Old 12-22-2004, 11:16 PM
Staff
DeathCougar's Avatar
If your brake fluid level is ok, replace the master cylinder cap. Inside the cap is a level sensor that makes the light come on when the level is low. I had this issue on my 87 4Runner, and replacing the cap made that go away.
Old 12-23-2004, 01:57 AM
85TurboRunner's Avatar
it could be the e-brake switch.
Old 12-23-2004, 03:56 AM
Slowrunner's Avatar
My brake light was on. It turned out to be my master cylinder cap sensor. I can,t remember how much the dealer wanted but it must have been a lot because a just ended up disconnecting it. The light will come on when the emergency brake is pulled , so I figure why bother replacing it.
Old 12-23-2004, 04:04 AM
PirateFins's Avatar
Bunch of know-it-all's up above think they got all the answers! Ha I'll show them!
Ok Ok I'll get this one guy's.
It is either your brake fluid is low, or the sensor in your cap is bad, or your e-brake switch is malfunctioning, or your altenator is going south, or your cable is sticking not disengaging under the truck.
Old 12-23-2004, 05:20 AM
lee
lee's Avatar
brake fluid.
Old 12-23-2004, 07:54 AM
4runn94er's Avatar
Question hmmm
i think...i'm no expert, but it could be that we just had an equanox shift of the lateral galixy and the fibulator might be fibunotlating. in short. The brake fluid... oh and if your lights are also dimming the altinator. but i think someone already may have mentioned these things oh say 1 MILLION times already!!!
Old 12-25-2004, 06:16 PM
Bigblock's Avatar
It could also be a bad diode in your insturment cluster. Finally, A fresh idea.
Old 12-25-2004, 07:21 PM
waskillywabbit's Avatar
My brake lights stays on all the time...but ripping out the parking brake and the sensor on the MC might have something to do with it...
I'd try topping off your blinker fluid via your MC.
Old 12-26-2004, 07:12 AM
The muffler bearing may have seized, tripping the light fandango sensor!
Old 12-26-2004, 07:27 AM
Yota4runner's Avatar
Mine does the same thing every once in awhile. However, mine does it because of the little spring/whatever it is behind the handle. it hit its and pushes the handle out slightly making the light come on. but, I'd check what the guys above said first.
Old 12-26-2004, 11:22 AM
rowan's Avatar
this happened to me - was the brake fluid. it's gonna be like right on the max line on my rig or else it will come on
Quick Reply: my ((brake)) like wont go out. :(
