Multiple problems
Multiple problems
I am having multiple problems with my 2004 Toyota Tacoma, it has 202,000 miles. The front end vibrates when going over 50-55 mph, the tread on the front tires are wearing to the inside, and my steering wheel shakes\rattles. The rattling and vibration ate getting very annoying, as well as the tires. Any help would be appreciated.
What is oe and what's been replaced? Anything aftermarket? Steering otherwise feels?
while you're at it have them balance and rotate your tires. most vibrations (especially ones that show up starting around 45 mph) originate with an out of balance wheel and tire. loose parts will amplify this. but your tire wear comes from poor alignment or loose steering/suspension joints.
I know my CV axle boots are busted, I think I need steering rack bushings because I can trurn the wheel when not moving and the steering rack with rock back and forth, I think my wheel bearings are bad, I'm taking the truck to an alignment shop hopefully tomorrow so they can tell me all that's wrong with it
Have the lower ball joints ever been replaced? There's a known problem with them and they seem to fail at about 200k. I am over due to have mine done too.
Don't skimp on em, get them from the dealer.
Many aftermarket joints are known to be weak.
You might check with the Toyota dealer before repair, I believe that there was a recall on these joints.
Google it.
Google it.
Hey man, check the control arm bushings also, upper and lowers. I see them on a lot of tacomas and 4runners around this year. They tend to crack and break apart. Then the bushing falls out of the control arm, causing the movement. And yes, also check your rack bushings. They do the same thing. My 04 doesn't have any issues yet. And I'm sitting at 213k. Let me know what you find!
The uneven tire wear is from suspension components being worn out and broken too. Check those control arm bushings. And there is no point in taking it to an "alignment" shop when there is obvious signs of worn components. Almost all dealerships will do a free multi-point inspection, if you live anywhere near Phoenix I could help you lol. Let me know!
Check it all out real good a replace any and all other worn front end parts you find. Slack in any of the components will damage the rest of them. Address those cv axles while you're in there. The more stuff you have removed, the easier they are to yank out.
Listen to Millball and don't skimp on any of those front end parts. A catastrophic failure of any of your front end parts at 70 mph will get you hurt or worse.
91Runner
09-12-2002 11:49 AM
craneman
09-08-2002 05:05 AM
