Muffler Tip
Old 08-30-2004, 08:45 AM
2002 SportEdition's Avatar
Muffler Tip
Muffler Pros:
Will it do any bad to your engine if you have the exhaust tip smaller than the exhaust pipe? I mean, can I use the 1.75" - 2.0" tip on the stock exhaust with 2.25" pipe (2002 model)?
Old 08-30-2004, 09:28 AM
Flamedx4's Avatar
Yes, it is bad. BUT, how would you put a 2 inch tip on a 2 1/2 inch exhaust in the first place? Slip it inside? Use an adapter? If you managed to do it, it would cause restriction which is last thing you want.
Old 08-30-2004, 11:59 AM
I bought a very nice "Pimping" tip which has 3" inlet Diameter and the outlet diameter is 3.5" with 2" Resonator. It is a slip-on tip.
So, this should not and cannot be used???????????????
Old 08-30-2004, 12:15 PM
lee
lee's Avatar
hahah. thats what receipts are for
Old 08-30-2004, 02:03 PM
Flamedx4's Avatar
You sure you don't have it backward there? Look in it and see. EVery resonator tip I could find specs for has a resonator insert that is larger than the pipe it fits. (i.e. 3 1/2" chrome tip with 2 1/2" resonator insert fits up to 2" pipe. etc)
Old 08-30-2004, 03:44 PM
This is what I have.
Specs:
Fits 1-1/2"-2-1/2" exhaust pipes
3-7/8" outer diameter
3" inner diameter
2" Resonator diameter (Not really 2" though, about 1.75")
Roughly 7-8" in length
Simple, 3 turn-screw installation
Old 08-31-2004, 09:29 AM
Flamedx4's Avatar
looks like it's okay, the "fits 1 1/2 to 2 1/2 pipe" and the 3" inner diam is the key items.
Draven023
13
10-08-2015 04:43 AM
hiluxinargentina
09-30-2015 11:12 PM
voiddweller
09-28-2015 11:21 PM
Keithstoyota
09-27-2015 07:29 AM
Quick Reply: Muffler Tip
