Muffler from another make?
hey i have a friend who has a stock muffler from a subaru wrx, hes guna give it to me and i was wondering how you guys would think it would sound on my 22re? im just curious and im guna try it espesially since its free
4"????
No way... stock?? If it is true, I wouldn't use it. Your going to have no torque what so ever. With a forced induction vehicle (espcially a turbo) the less backpressure the better. See, the turbo will provide all the backpressure you need on top of the fact taht the turbo is blasting as much air into the engine as possible, so the more backpressure you add on = powerloss. With our N/A trucks its quite opposite, not only are our engines designed for torque not high end hp they don't have that backpressure provided by the turbo. C'mon, you can get a muffler for under $50. Check 96Runner's sig, he has a setup installed for $50 or something like that.
As for tubing, I wouldn't say its worth it. I didn't do it. I figure I'd just keep it cheap til I S/C it and then it will be a little more worth it. Or if I get a rear bumper I will intagrate it so its protected from rocks as mine is already bent up from tellico. Though with the body lift it doesn't look too bad with it bent...
my .02
my .02
still the point is the inside is 4" and if you are going to run an small to large adapter to the muffler then a large to small adapter out of the muffler... its just dumb... serious... it wont give you the right backpressure becasue again ,its for a car thats a turbo and probably ppushes out almot 3 times your power numbers
Well, your going to pay at very least $20-30 to get the thing put in then another $20 to get your stock muffler put back in. By that point you could have gotten a good muffler.
09-04-2015 09:27 AM
HookahRoo
07-20-2015 07:06 PM
