mt/r on 1st gen
mt/r on 1st gen
whats the biggest size of mt/r i can fit on a stock 1st gen... 265/75 MT/R's? should i not go that big? im running 235/75/15's now.. thanks for the responses in advance
kelly
kelly
Is that tire size on a 15 or 16" wheel? If it is 16 - Crank your torsion bars and then go with a 1.5" shackle lift in the back and you can fit those. What engine, tranny, gear ratios you have?
If it is the 15 inch wheel size then it should fit stock.
if you going to run the stock steel rim which is a 15x6, then 235/75R15 is the largest tire. if it's the stock alloy rim which is a 15x7, then you can run a 31x10.50R15.
if you aftermarket rims, then you should check on the width of the rim. and go by this... (stock, no lift)
15x6 - 235/75R15
15x7, 15x8, or 15x10 - 31x10.50R15
you probably can fit a 32x11.50R15 but you'll rub some.
15x6 - 235/75R15
kawazx636
10-06-2021 03:03 PM
Toys4parts
09-26-2015 01:56 PM
