Motor Mounts
Motor Mounts
I did some searching and can't seem to find anyone who makes poly motor/trans mounts for the 1st gen Tacos (i'm a V6). I don't really want to go with solid mounts due to the fact that they translate a lot of vibration and harshness into the cab.
If anyone has any info on where I could purchase a set of poly motor/trans mounts that would be great!
Thank you,
-Brian
Thank you,
-Brian
Can I ask why you're looking for better motor mounts? Do they need replacing or are you worried about the power of the supercharger being there?
Stock works just fine.
Good question.
The stock motor mounts are beginning to show signs of deterioration (small cracks in the rubber). Also, when all is said and done, I will be in the neighborhood of 300hp. I would like as much of that power as possible to be transferred to the wheels of the truck and not the rocking motion of the motor. That is over a 50% increase in power over the stock 5VZ-FE. Hence the desire for the poly mounts.
Don't know if these will work for you but they do list a V6, are you a 3.4 or 3.0? Email him, maybe they'll still work or maybe he can make you some.
MOUNTS
MOUNTS
And regarding the mustang, you have to remember that chassis was built to handle more power and I am willing to bet those motor mounts were a lot stronger than the stock 5VZ-FE mounts.
jon.r
07-11-2015 03:34 PM
