Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
More road/engine noise after clutch replacement?
__________________
| '97 4runner 5spd SR5 w/ Tan leather int. | Diff. Breather | Hella 500 Driving Lights | Alpine 9856 Headunit | Old Man Emu 3" lift from Toytec | Green Tokicko Shocks| 265/75/16 BFG A/T | SS Diff. Drop | Polk Audio db6501 components | Profile AP600 amp. | Alpine MRP-M1005 amp | 1 Polk Audio SR124 DVC Subwoofer |
#2 (permalink) |
Personal
Sales Rating: (0)
[OP]
After taking a closer look under the transmission is seems there are clips (possibly for padding?) that do not have anything attached, above the transmission. Any thoughts or anybody know?
__________________
#3 (permalink) |
Personal
Sales Rating: (0)
No there is no padding or sound deadener.
__________________
SHUT UP AND WHEEL. My 99 Tacoma Single Cab build. Now representing All-Pro Off-Road. Call us for all your suspension and armor needs. 951-658-7077 |
#4 (permalink) |
Personal
Sales Rating: (0)
[OP]
Just got off the phone with the dealership, they said something should be there but he wasn't sure whether it was a shield or sound absorption mat...there are also those plastic pins there as well. Can anyone else confirm?
Thanks for the response scuba! Would like to get a couple more confirmations as things just don't add up right... also there could be differences between the 4runners.
__________________
#5 (permalink) |
Personal
Sales Rating: (0)
Well, there's a shift boot, but I figure you'd have taken that our when you started the clutch job and put it back in. Pics??
__________________
#6 (permalink) |
Personal
Sales Rating: (0)
[OP]
I didn't do the clutch job myself. I didn't have any time to mess around with it as I'm in the middle of a semester at school. But it just made an impression on me that starting the 4runner and accelerating were noticeably louder. I guess a broader question would be what could possibly have happened (if anything at all) that would cause this issue?
__________________
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
I'll try and post a picture of the plastic clips I'm referring to. I appreciate the feedback
__________________
#8 (permalink) |
Personal
Sales Rating: (0)
Check under the leather shift boot/ console trim for one of these:
__________________
#9 (permalink) |
Personal
Sales Rating: (0)
[OP]
I opened up the boot assembly pictured above and noticed that part of the body was bent, I'm guessing when they were lifting the transmission back up into place. This caused the rubber isolation and boot assembly to not sit correctly and let road noise directly through. I hammered it back in and now it is just like it was before.
Although this problem is solved I have noticed a lot more "shutter" when starting from 1st gear. The whole transmission violently shakes. This used to happen occasionally but now it happens very frequently. Is this associated with machining the flywheel. Or what could possibly be there problem there. I will call the shop about it Monday but just wondering. Thanks for all the help!
__________________
#10 (permalink) | |
Personal
Sales Rating: (0)
I'd asked for info for my first clutch replacement in a yota and space-junk posted this link.....
Quote:
__________________
My rides: '96 4Runner SR5 4x4, manual. Stuff happened to it. Stuff is still happening to it. '99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...but not too much stuff. http://www.yotatech.com/f200/habaner...thread-201751/ |
#11 (permalink) |
Personal
Sales Rating: (0)
Looks like you solved the noise issue, but just so you know, the only padding under there is the small heat blanket that goes on the firewall and kind of wraps down. In no way is that going to effect transmission noise. that must be what your dealer was talking about.
__________________
--Jason 1992 Toyota Pickup Ex-Cab 3.4 swap DONE <-- to lookie Converted auto harness to manual R150 manual Dual cases 2.8/Marlin 4.7's Marlin MC-07 adapter 4" Pro-Comp lift terribly installed by previous owner and a crew of 1st graders it seems SAS in gathering stage |
#12 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks for the responses and help. The "shuttering" or "chatter" in the transmission has considerably gone down, or is almost nonexistent. Every once in a while it will not catch right but the shaking is much less severe and only happens for a split second. I will wait maybe another week and see if the problem completely goes away as the link above stated that although the problem mainly results from improper torquing of the pressure plate, it can also occur while breaking in the clutch. I'll keep everyone posted. Thanks for the help again!
__________________
#13 (permalink) |
Personal
Sales Rating: (0)
Sounds to me like your clutch skills need some work.
How many miles did your last clutch last ?? |
#14 (permalink) |
Personal
Sales Rating: (0)
[OP]
#15 (permalink) |
Personal
Sales Rating: (0)
[OP]
Another question...When I got the 4runner back initially the clutch engaged very early in the pedal release. Now it is engaging up high like it used to be before I got it replaced. This isn't to say that it has been slipping or anything (at least from what I've been able to notice) but I was wondering what causes this mechanically or is this what should happen?
Thanks for the help guys...
__________________
#16 (permalink) |
Personal
Sales Rating: (0)
[OP]
Any thoughts on the difference of clutch engagement since it came out of the shop?
__________________
#17 (permalink) |
Personal
Sales Rating: (0)
I think whoever installed the clutch for you may have contaminated the disc surface with oils or some kind of liquid which would cause a chatter upon contacting the friction disc, probably just an over-looked situation aggravating for the time being and could cause premature wear of the disc surfaces.
Also, if the clutch is shuttering like that upon engagement/ dis-engagement it would indicate the possibility of the the clutch pedal free-play being out of spec. Sounds to me like the technician may have rushed through the process or wasn't quite competent enough doing this job. Keep an eye on it, if the problem persists or worsens I would go back to the technician and have him verify your concern, chances are that clutch is now damaged.
__________________
It's the music that's by your side when you ride at night It's the music in your life that takes you to the other side It's the music in your life The music in your life |
#18 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thank you very much for that response dubbsbetty...I certainly hope that the clutch hasn't been damaged but will be taking it back to them first thing tomorrow.
__________________
| Tags |
| breaking, cab, change, clutch, engine, gearbox, installation, noise, noises, noisy, replace, replaced, replacement, sounds, tranny, yotatech |
