Modifying steering lines for 6" DB Lift "HELP!!!"
Lots of searching and no good solution yet.
I'm looking at PSC's 16mm inverted flare to JIC#6 hydro adapter fitting. Talked to PSC and they couldn't confirm if thier fitting would work on a Taco rack but it looks like it will.
I just can't be comfortable with bending and kinking my stock lines and that being ok. My very first bend began to crack the high psi line at the hard line to rubber line crimp fitting.
If I could swap to all JIC#6 Hydro lines that would be great but not looking good for a JIC#6 to Taco 16mm banjo bolt (for power steering pump line fitting)
https://www.yotatech.com/forums/f129/
may be able to find more in this part called "Off Road Enhancements"
09-04-2015 09:27 AM
pyramid
07-30-2015 10:05 AM
coffey50
07-28-2015 10:55 AM
terminator
07-27-2015 07:13 PM
whereAreMyPants
07-22-2015 03:32 AM
