| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Mobil 1 synthetic....Differentials?
__________________
1995 4Runner*3.0 V6*Auto*K&N filter removed(JUNK)*Keyless entry*Remote Start*Viper Alarm**Bilsteins*Downey 1.5 coils*LA Tint*Dynomax muffler*Haden Tranny Cooler* |
#2 (permalink) |
I just replaced my diff fluid and asked the dealershiop if that was ok. They said yes. That most of the really good synthetics are not a straight shot wieght.
Amsiol 80W-90 Mobil 1 75W-90 So you'll be alright. 75W - 90 means that it can act like a 75 W to a 90 W.
__________________
-Yosmany 2004 4Runner SR5 V6 Westin Safari Bar, 20" Enkei w/ 295/45/20 Faulkens, 15% Window Tints, OEM XM Radio with Scion HU, 1995 & 2005 Chrome v6 Emblems, Toyota Hood Protector, Spoiler, AVS Tail Light Covers Painted, K & N Air Filter, Passport 8500 Radar Detector, Dual Borla Exhaust, Cornfed 2"/3" Lift |
#3 (permalink) |
75w90 is fine anywhere you would use 80w90. It's just slightly thinner when it's cool. At operating temperature, both are are similar weights and will act the same.
__________________
-Rob Slightly Modified 2001 Tacoma - WATRD.COM WATTORA is becoming NWToys! Tread Lightly! certified Tread Trainer Search 100+ Toyota tech sites, including this one: Toyota Tech Search |
#4 (permalink) |
I'm confused a little because I keep seeing 80w-90 talked about for the 4th gen's but my Owner's manual says 75w- 90. Is the 80w - 90 a personal preference or did you guys read it somewhere that that is what is recommended for 2003's???
I just ordered 7 qt's of 75w - 90 from amsoil to do my diff's and transfer case so I hope that I am right. Yosmany, amsoil has 75w-90. |
#5 (permalink) | |
Quote:
__________________
~Dale~ 93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, 1.5" ball joint spacers, manual hubs, TJM T-17, Warn m8000. |
#6 (permalink) |
Thanks everyone........Makes me feel more at ease.
__________________
#7 (permalink) | |
Guest
Quote:
A synthetic gear oil can be a very good thing. There is a lot of parasitic power loss in thick gear oils. Going to the much freer flowing synthetics can give a discernable performance increase and fuel mileage increase. That said, make sure your seals are in good shape. Synthetic oils do a great job of creeping past seals and such. A damp spot becomes wet, and a leak becomes a river when going with synthetic oils. |
#8 (permalink) |
i've been running mobil-1 synths since about 2001 in my 99'er. no probs so far, loving it, my truck is a happy truck.
#9 (permalink) |
Question for TRANS_DUDE
I flushed my tranny and filled with Vavoline max life.....says for Toyota. In a post a while back you mentioned adding LubeGuard...I have a bottle of LubeGuard and need to know if adding to Maxlife would be to much friction modifiers? or would it be ok? Thanks
__________________
#10 (permalink) |
Sorry about that reply...wrong post...
__________________
#11 (permalink) |
I've had M1 75W-90 in both diffs, the transfer case, and the manual transmission for the last 2 years. It works fine and shifting in cold weather is noticably better...
__________________
2000 4Runner SR-5, 4X4, 5 Speed, Toyota locker. Dunlop R/T's, cheap mudflaps, remote oil filter, deckplate. My 4Runner |
#12 (permalink) |
I put Amsoil 80W-90 in the rear differential and 75W-90 in the others, but it's just because I could. Amsoil had both weights.
Before I went with the Amsoil, I was going to buy the "Toyota" brand gear oil. The guy at the dealership service counter told me they just put regular stuff in. He didn't even know what brand. He said they use 75W-90 in everything including the rear. He said it didn't make a difference.
__________________
Nic 1997 Tacoma 4X4 Xtra Cab 2.7L 5 speed |
#13 (permalink) |
I just switched to Redline fluids in the gear boxes and expect no problems since that was all I ever used in my Eclipse for 8 seasons of racing.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#14 (permalink) |
Yeah, on that note, I should have said earlier that I too switched to Redline MT-90 in the transmission because of the notchiness in shifting with the Amsoil. It seems the Amsoil is too slick for the synchronizers-So they say. I don't have a clue about how transmissions work.
It helped, but did not completely cure the problem. There are some threads on this subject if you do a search.
__________________
| Tags |
| 4runner, 4x4, 75, 80w, 80w90, 90, amsoil, diff, differential, mobil, mobile, oil, rear, synthetic, tacoma, toyota |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Front Differentials? | JustAnotherJodieFE | 86-95 Trucks & 4Runners | 5 | 01-19-2006 10:45 AM |
| Mobil Synthetic - HIgh Mileage | hill | General Vehicle Related Topics (Non Year Related) | 19 | 11-30-2005 09:14 PM |
| Mobil 1 vs. MOBIL 1 EP fuel economy | yota4me2 | Maintenance & Repair Archives | 15 | 02-24-2005 08:11 AM |
| Weight of Differentials? | justinh | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 04-30-2004 01:25 PM |
